Vavle cover question
Old Dec 23, 2006 | 09:07 AM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Why can't I find any valve covers to fit my 1991 305 TPI on Summit? I do know they are 4 bolt centres, but that's all I know
Would these fit it? http://store.summitracing.com/egnsea...115+4294840138
It was a search of summit of 4 bolt centres, leaving out 1991 camaro data. just 1991 5.0/305.
yks troy
Old Dec 23, 2006 | 10:00 AM
Demon355's Avatar
Look for Centerbolt design valve covers.
Old Dec 23, 2006 | 11:56 AM
BOTTLEDZ28's Avatar
Transmission: A4
you can find a pair of chrome valver cover covers. They simply go over your factory covers. No need to mess with the gaskets. its a real pain getting the valver covers on and off your car if all the factory stuff is still attached on the engine. You can also look on ebay for actual valve covers. I bought a pair of tall polished aluminum ones for mine for $100 on ebay and they fit nice and dont leak. I will be tossing them though so I can get a set of some GMPP covers. Ill just need to run my adapters.
Old Dec 23, 2006 | 12:06 PM
Car: 1991 Z-28
Transmission: 4L60
I am changing the valve stem seals, so I figured I would change the valve covers too.
So any of these covers on summit http://store.summitracing.com/egnsea...115+4294840138
will fit a 305 TPI with centerbolt? Just wanted to make sure before ordering, because when you add in Camaro to the valve cover search, I only end up with gaskets.
Tks Troy
Old Dec 23, 2006 | 12:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
yes 90% of those covers will fit your engine. As long as it has the holes in the center of the cover and it says SBC, they should fit. The only issue you run into is when you run roller rockers. Some rockers are bigger then stck and then some valve covers dont fit without modifying the covers.
Old Dec 23, 2006 | 12:47 PM
Car: 1991 Z-28
Transmission: 4L60
Thanks man..that really helps!..everything internal is stock so it should not be a problem! Thinking of these: http://store.summitracing.com/partde...5&autoview=sku
and to all, thanks for not making fun of my spelling in the post title
BTY that silver looks awesome on your Z !!
Last edited by patricktroyz28; Dec 23, 2006 at 12:49 PM. Reason: Automerged Doublepost
Old Dec 23, 2006 | 12:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
nice choice on covers. as for your spelling issue, you can correct it by editing your post then go to advanced and fix it in there. Then save your work. Oh and if you decide to go withthe rubber felpro gaskets, be prepared to cut them in half for them to fit. it says on the box that they are made undersized on purpose. They will NOT fit inside the groove of the cover and stay there while you try to fit the cover in place. I always cut the gasket in half and then glue it to the cover with gasket maker and let it sit overnight. I have never had an issue with them leaking.
Old Dec 23, 2006 | 01:27 PM
Car: 1991 Z-28
Transmission: 4L60
Thanks again for the tip!
Old Dec 23, 2006 | 05:08 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
those black covers with the red Chevrolet look freaking awesome. i would so get those if i had the money.
good luck with the valve stem seals patrick!
Old Dec 23, 2006 | 05:26 PM
Car: 1991 Z-28
Transmission: 4L60
Oh Dan the $$$$, just hooker 2055's and y pipe, hi flo cat, catback exhaust and valve covers for me this year..not to mention building a 20X24 barn style garage this summer!!
Thank god for a wonderful wife!! All car stuff got to get the bosses approval!
Old Dec 23, 2006 | 05:53 PM
rwdtech's Avatar
right on man! im hoping the camaro is gonna go in that new garage.
do the valve covers at the same time as the headers, i remeber i had to take off one of my valve covers to get the headers to slide in there. plus you will be removing all that coolant crap on the passenger side of the engine next to the intake manifold.
Old Dec 23, 2006 | 05:58 PM
Car: 1991 Z-28
Transmission: 4L60
Another awesome tip from you guys
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
