your antenna
Old Jan 9, 2007 | 12:48 AM
Gramps's Avatar
Car: 87 Camaro IROC
your antenna
what did you guys do with your antennas? i wanna shave the antenna and relocate it but was wondering what you guys did.
here is a pic of that antenna ruining the epicness of the photo
Old Jan 9, 2007 | 12:50 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
power antenna - tucks out of the way pretty good when the radio is off.
just a thought.
-Schultzy
Old Jan 9, 2007 | 01:11 AM
Gramps's Avatar
Car: 87 Camaro IROC
ya i have looked around but all i can find are chrome bodies, i want the flat black body because chrome does not belong on my car...anywhere!
Old Jan 9, 2007 | 11:34 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
shaved it...put it under the dash...and it works pretty good...I don't listen to the radio much...but when I do...it's not bad
Old Jan 9, 2007 | 01:30 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
i unscrewed my factory antenna and have yet to have any radio reception problems. it looks much better. the antennas on these cars are in such a bad location and look so out of place
Old Jan 9, 2007 | 02:26 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Nothing a can of paint won't fix. And for something like that, it would last years before needing a repaint.
Old Jan 9, 2007 | 06:34 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I shaved mine and went with a 12 volt powered antenna. its mounted inside on the windshield above the mirror. Reception is amazing and the antenna is barly noticable which is nice. it was only like 20 bucks so its worth it. ill try to grab a pic tomorrow.
matt
Old Jan 9, 2007 | 07:36 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Hah, GM used to put the antennas in the windshields, like on my Malibu.... You cant see it unless you look for it, and it works well! why did they stop doing this?
Old Jan 9, 2007 | 07:48 PM
Gramps's Avatar
Car: 87 Camaro IROC
can you buy antennas that glue onto your windshield like the rear defrost? that would be amazing if i could have that kind of hidden antenna.
Old Jan 9, 2007 | 07:54 PM
They make those kind. Ive tried a few on other cars but they dont work very well.
matt
Old Jan 10, 2007 | 10:12 AM
well thats basicly how it is on my malibu......
two thinnnnn thinnn little lines that go up the middle of the windshield, probably the same **** they make the defroster lines out of, and it works mint!
Old Jan 10, 2007 | 10:53 AM
Stephen's Avatar
Car: 87 GTA
I did the same thing to my old 92 RS. Never had a reception problem.
Old Jan 10, 2007 | 11:00 AM
Gramps's Avatar
Car: 87 Camaro IROC
any ideas on where to get such a product?
Old Jan 10, 2007 | 12:36 PM
84 trans am's Avatar
Car: 89 RS
Engine: 2.8
Transmission: t5
We have them here at Radio Shack. $3.49. Should be the same at about every one of em.
Old Jan 10, 2007 | 03:31 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I vote for the retractable power unit. Look at my image below in my sig.. power antenna is down and you can just barely see the nipple from which it extracts from.
Old Jan 10, 2007 | 09:28 PM
Kandied91z's Avatar
the unit gm uses that works well costs more which is why they are usually offered on the high end versions. for example grand prixs get them on the gtp version.
i have yet to find a power unit that works well. i've been using the factory antenna just stuck up under the dash because both my $100 dakota digital and $4 radio shack version don't work as well as the gm unit. if i could find a gm unit stand alone i would do that first.
Old Jan 11, 2007 | 11:05 AM
Daytona T/A's Avatar
Car: 1983 25th Anniversary Daytona 500 Pace Car Trans Am
Engine: 5.0L 305 Crossfire-Injected V8
Transmission: 4 spd. auto
power antennas are great... until they break.
Old Oct 13, 2007 | 03:27 PM
83 Crossfire TA's Avatar
Re: your antenna
Where under the dash are you guys stashing a full size antenna?
Old Oct 13, 2007 | 03:34 PM
Pocket's Avatar
Car: 91 Trans Am
Re: your antenna
Sandwiched under the dash pad or just above the pass side hush panel
Old Oct 13, 2007 | 04:43 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Re: your antenna
I disassembled the power antenna that came with my '92 and fixed it. Basically it just needed to be greased and re-assembled. One of the mast sections was slightly bent too. I still haven't actually replaced the rivets that held the case together...oops.
Anyway, I like having the power antenna and like Brisk said all you see is the little bezel the antenna comes out through!
Just my .02, but if you shave it and put it in the dash or use one on the windshield that obviously works too!!
-Paul
Old Oct 14, 2007 | 06:40 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: your antenna
I love my power antenna. I bought a broken one off eBay and the repair kit from MDM and fixed it. I'm going to paint the bezel red to match the rest of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
