You guys with the White Guages and the Bulbs>>>>
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I want to get a set of bulbs for my 91z but if I rember correctly((been a long time))
I pulled one out once and it was attached to a plastic holder that twisted in to the back of the cluster and I tried to pull one of the bulbs out "WOOPS" and I didn not know that it was attached and broke it....
When you buy the X-bulbs do they come in it or is there a way to put then in their little plastic holders??
Thanks for any info!
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hecubus
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
When I put in my white faced gauges I replaced the bulbs and pretty much broke all of them to get em out.. the bulb has little metal contacts I guess soldered on to the metal peice on the holder.. the new bulbs will have 2 metal contact just pull them out and bend them over the metal peice on the holder and stick em back in.. you could of course soldering them in again if you want but I didnt and it seems to work fine..
1991 Camaro Z28
ENGINE/MECHANICAL MODS:
350 TPI, automatic, Edelbrock Headers, Edelbrock Runners, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000 Reciever, Q-Logic Dual 10" Bandpass Box, 2 10" MTX Thunder 7000 Subs,
Rockford 250a2 Amp, Infinity Kappa 4x6" plates & 6x9's
Visit my website and see pics at: Frank's 1991 Chevrolet Camaro Website
1991 Camaro Z28
STEREO MODS:
ambainb
Apr 25, 2016 09:21 PM
