18" Torq Thrust II's
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Does anyone have the 18'' chrome torque thrust II's.
All the 17's come polished
ill post when installed. Any Pics of the 18's
Tires are 295/35R18 in rear on 18x10
255/35R18 in front on 18x8 do u guys with 18's think I will have clearence issues or rubbing problem
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The wheel size doesn't have anything to do with clearance and rubbing, it's the tire size. The only contribution the wheel has is the offset, which can have a major effect if it's not correct.
A 255 35 18 up front should fit fine. That should be about the same diameter as a stock tire, and not much wider.
A 295 35 18 is massive and may indeed create many headaches. That's gotta be close to a 27" tire, plus it's too wide to fit within the wheel well, so some of it will be under the quarter-panel lip, so you may have rubbing issues depending on your suspension.
Car: '02 Z06
I'm gonna disagree with Jim on this one and say it's 100% dependent on the wheel and NOT the tire size. I'm running 285's in the rear and could easily go to a 295 without worry (not that i'd want to though as my rear wheels are 9" wide and a 295 would bulge a bit more than I would like).They tuck in just like a stock wheel with no motifications to the body..this on a lowered car.
With that 10" rear width you can go as deep as about a 6" backspace before you're going to have to worry about rubbing on the inside..too little of backspacing the wheel will stick out and possibly rub on the outside. I prefer a wheel that tucks in close rather than sticking out..it's all personal preference. It's also dependent on your suspension setup as Jim said.
Your total overall width and diameter at the tread surface is what matters. The only impact the wheel has on this equation is the centering due to offset. Everything else is based on the tire. Stick a 275 on an 8" wheel or a 9" wheel and nothing (or at least very, very little) changes at the tread surface. Likewise, run a 275/40/17 or a 257/35/18 and nothing changes at the tread surface. The wheel doesn't matter except for offset changes. However, the difference between a 275/40/17 and a 285/50/17 is huge, and will have an impact because your total rotating dimensions are different.
Car: '02 Z06
I agree, but what I'm trying to say is that it's entirely possible to fit that size tire without modifying the body..it just depends on the specs of the wheel.
COTM Editor
I run 18x9 and 18x10 on my car with a 285/35r18 in the rear, and I have no rubbing issues at all. I will be moving to a 295/35r18 in the rear hopefully this summer. I massaged the inner fender wells before I even went to the 18" wheel, but it would not have mattered cause these wheels don't let the tire get that close to the inner fender.
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Uhhhhh, the 17's are also offered in a one piece chorme form. Go to summit.com. I got the polished for 1250 and if I were to get chrome the price was 15sumthing.
Re: 18" Torq Thrust II's
The wheel doesn't rub the wheel well, the tire does.
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I have 18x10's on all four corners. With 285/35/18 on all four to. They are 4th gen rims with 2" adapters. The fit awsome with NO rubbing unless I lock there steering wheel all the way to the sides. If I had the IROC steering box with the stops in it for the 16 inch rims. I think there would be know problems. They are polished(well supose to be anyways. The finhsed needs alot of work.). I don't know if they have them in chrome. Adam :-)
LT1Formula
Nov 16, 2015 01:13 PM
