do I have a clear coat finish or regular paint finish on my car (Zaino Question)!!!
Old Apr 22, 2001 | 07:06 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm thinkin' about getting some Zaino polish for my car but I don't know if I should get the Clear coat polish or regular paint polish! I have an '86 Trans Am and I know it was repainted before I bought it because they changed the color and you can still tell where some of the old paint is!! I don't know if they put a clear coat on it when they repainted it though! So which polish should I get or how can I tell whether it has the clear coat finish???
Old Apr 22, 2001 | 07:39 PM
TwicK91's Avatar
I believe if you put some wax on a towel and apply/remove from the car the towel should turn the color of your car if you don't have a clearcoat.
Old Apr 22, 2001 | 07:51 PM
<font face="Verdana, Arial" size="2">Originally posted by TwicK91:
I believe if you put some wax on a towel and apply/remove from the car the towel should turn the color of your car if you don't have a clearcoat. </font>
Ohhhh....so that's it! When I used the Meguiars wax the applicator pad always turned red (the color of my car)! So I guess I don't have the clear coat! Thanks!
Old Apr 23, 2001 | 09:11 AM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
I know how you feel 86Tpi. The person who owned my car before me got it repainted (crappy I might add) and my wax pad always turns black.
Old Apr 23, 2001 | 04:59 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I don't know if I agree fully with that statement. I have a gray 442 that I recently detailed thoroughly and the rags were the color I would expect them to be after waxing. I used a polishing compound by hand, then glazed, then waxed. The polishing compound removed dirt so it was pretty crappy looking. The glaze went on and came off the cream color it was. The top coat of wax obviously showed nothing at that point.
Another way to tell, with 1200 sandpaper,in an inconspicuous spot, lightly rub. If it comes up white, then it has clear coat, if it's body color, then it isn't. In either case, the sanding can be repaired easily by buffing.
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Northstar Camaro Club of Minnesota
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
