Headliner falling down, has any one over changed it
Old Apr 24, 2001 | 11:39 AM
gemmefire's Avatar
I have t-tops and some ppl told me that you can rip out the headliner and put in fiberglass but i dont know what to think of that. i mean it would probaly be easy and look realy good. if i was to keep the "headliner"(get a new one) how easy or hard are they to install correctaly
thanks
87 SC 2.8 V6
Old Apr 24, 2001 | 12:12 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
The headliners just click in after you take off the trim pieces by the A-pillar, B-pillar, and the plastic piece running across the back. You have to be careful if you are planning on reusing the same board because the area by the seat belts are really flimsy and they break easily. If you are getting a new headliner board then you should have someone professionally reapohlster it before you put it in. It is a hassle to reapolster these things. I just bought one from thirdgenresources and it should be here any day now. Their's came totally covered and the shipping was a lot less than buying the headliner from anyone else...
good luck,
Mike
Old Apr 24, 2001 | 03:05 PM
Z28DJP1987's Avatar
Check your yellow pages, and go to auto upholstery specialists. It cost me $160.00
and took them about 2 hrs. The fabric match
was perfect, just like the factory job.
1987 Black Camaro IROC (orginal owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam 450lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors
SLP Intake runners , New Computer chip
K&N filters & Air Foil ,
Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
Limited Slip rear (2:73)
245/45/17ZR Tires
17x8.5 ATP 5 Razze Wheels
EST. 340HP
380#/ft of Torque
NEW TOY!
Old Apr 24, 2001 | 03:45 PM
Aaron87SC's Avatar
Too much of a pain in the *ss . Cost me $200 and was well worth the money. (I have a hardtop)
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
L69 Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
Pioneer DEH-P4000, Pioneer speakers front/back
[This message has been edited by Aaron87SC (edited April 24, 2001).]
Old Apr 24, 2001 | 06:12 PM
Third's Avatar
I'm in the process of doing mine. Taking it down is easy but time consuming. You just take off all the screws holding the trim pieces and carefully pull off the headliner and board. My headliner didn't tear but was sagging, if it's in good condition I'm going to peel it off and reapply it with 3M adhesive. If not JoAnn Fabric has the exact same headliner material. I found a whole roll of it for my friend one time. Total cost was like ten bucks, material and adhesive. I haven't put mine back on because the weather has been crappy. It just takes some patience.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
deracer
Apr 11, 2016 12:04 AM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
