Final Results From Extremely Poor Man's Paint Job
Old Apr 15, 2007 | 02:17 PM
  #101
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Re: Final Results From Extremely Poor Man's Paint Job
Originally Posted by nelapse
Funny, you talk a good talk about the boy doing a great job because it was all the money he had and then there is this quote.
So in a nutshell, he did not do it to make his car better because it was what he had, he simply halfassed it. Too bad you made an essay supporting a thesis that he found untrue.
A thesis found untrue by you or perhaps misunderstood, until made clear by Camaro_Please?
Camaro-please?
I think you not catching my drift i will have money over the summer, but i was inspired to paint my car over spring break....A 16 year old dropping 2000 grtand on a paint job is really really really wrong....there are more important things (college)
A statement made by yours truly supporting his fact, prior to his correction
Psycho_91 Camaro
This is as best as he could do at the moment
Old Apr 15, 2007 | 02:25 PM
  #102
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Looks good, except for the hood there. What happened? Forget to sand something underneath or was it a paint run?
You can tell it's not a true automotive paint, it doesn't have the shine. Not sure if you can help it out by cutting and buffing it or wet sanding it, then adding clearcoat? (spray bomb clearcoat).
I think the only visible "oopsie" was on the hood. Since you've painted it in this method, you can go back and re-do just that one part right? You might want to consider that, since the hood is one of the most visible parts of the car.
Looks sharp, 10' away is good enough.
Old Apr 15, 2007 | 07:04 PM
  #103
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Use rubbing compound and rub the **** out of it.
Old Apr 23, 2007 | 05:03 AM
  #104
Charlie319's Avatar
I was reading this thread and did a bit of digging. If I were to think of doing this, which Rustoleum paint might be best suited to UV and weather abuse... They have a Marine Coating product that might be a decent option:
http://www.rustoleum.com/product.asp...t_id=305&SBL=1
Think about it...
Old May 8, 2007 | 09:07 AM
  #105
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I know i am kinda bringing this back from the dead. But i salute him for working with what he had and getting a nice finished product.
Old May 8, 2007 | 10:57 AM
  #106
rwdtech's Avatar
Car: 1991 Z28 (sold)
did he ever post pictures of the car outdoors?
Old May 8, 2007 | 12:42 PM
  #107
9D1BURD's Avatar
Car: 1997 Z28
I do not believe so, i will be seeing the car tonight though. If he does not mind, i will post what i think later on.
Old May 8, 2007 | 02:13 PM
  #108
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
"I know i am kinda bringing this back from the dead. But i salute him for working with what he had and getting a nice finished product."
a paint job that was applied with a roller over bondo is in NO WAY AT ALL a "nice" finished product.
Old May 8, 2007 | 02:45 PM
  #109
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
hey man, good job.. a roller is interesting. but i know what tight on money is like. im 16 and have no job. me and xgtharo86x have been painting my car with sandable primer when i can afford a can or 2. just going over the sunfade tho. also i like the 2toned paint scheme. heres a pic of how mine came out.
Attached Thumbnails Final Results From Extremely Poor Man's Paint Job-000_0133.jpg
Old May 8, 2007 | 04:01 PM
  #110
9D1BURD's Avatar
Car: 1997 Z28
Did you even look at the difference it made. For what he spent and USED, it was a nice finished product.
Had he spent say 500 dollars, then yeah, not so good.
Its all about perspective here.
Old May 8, 2007 | 05:30 PM
  #111
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Leave the kid alone.I have respect for him for painting his own car. The way I see it is live and learn. you must do it before you know how to do it right. you don't start off in math knowing the answers, you need to learn and make mistakes before you know how to do it right. I spent all day using rubbing compound and polishing my car. If I had bad paint on my car, I would do the same thing. to a fellow 16 year old. I am right there with you.
Old May 8, 2007 | 05:58 PM
  #112
1988CamaroSC's Avatar
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
Old May 8, 2007 | 06:00 PM
  #113
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
EVERYONE IS ENTITLED 2 THEIR OWN OPINION. ITS SHABBY BUT WAY BETTER THAN B4. REMINDS ME I NEED TO REPAINT MY CAR WHEN I GET SOME FREE TIME. THE PICK THAT IS POSTED IS OLLLLD AND THE PAINT LOOKS RED INSTEAD OF BRANDY WINE(MAROON). SITS IN THE SUN 2 MUCH, BUT I HAVE BEEN REDOING EVERYTHING STARTED FROM THE MOTOR OUT!
Old May 8, 2007 | 06:11 PM
  #114
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
It's a good job that he did. Nothing wrong with it at all. At least he had the motivation and the willing to step out of the comfort zone and do the thing himself rather than just having more money than brains to throw at it like some of the posters on this thread seem to have. You know it is a "good" paint job when you spend over 5 thousand dollars and just have someone else do it for you? Nah. It's a good paint job when you do it yourself, get some education in during the process, and are happy with the results. Kudos to you, my young friend, and don't let these money mizers bring you down.
Old May 8, 2007 | 06:22 PM
  #115
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Camaro-please? did you ever get some outside pix of it, curious to see how it looks. It looked like it came out of a grave before you painted it...
-I just got an Earl Schieb paint job, not bad, but I plan on "flash" (meaning Im not going to spend a lot of time, just 2k grit and polish) wet sanding it and when its done it will look like a 2k paint job (Ive done it before, big diff). I mean, its only 3 weeks old and already have rock dings etc. No point in spending a lot of money on paint unless its a show car or weekend cruiser or if you just plain got the $$cash$$ ya know.
Old May 8, 2007 | 06:27 PM
  #116
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
He updated his first post weeks ago.
Side 1
http://i53.photobucket.com/albums/g6...m/HPIM1016.jpg
Side 2
http://i53.photobucket.com/albums/g6...m/HPIM1019.jpg
Rear
http://i53.photobucket.com/albums/g6...m/HPIM1017.jpg
Front
http://i53.photobucket.com/albums/g6...m/HPIM1020.jpg
Side 1 Farther away
http://i53.photobucket.com/albums/g6...m/HPIM1015.jpg
Side 2 FatheraWAY
http://i53.photobucket.com/albums/g6...m/HPIM1018.jpg
Old May 8, 2007 | 06:33 PM
  #117
Car: 1990 Firebird
Engine: 3.1
Did not notice that. Hmmm, not bad at all.....
Old May 8, 2007 | 08:26 PM
  #118
Camaro-please?'s Avatar
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
Yea i just edited the first post i had because i thought it would be more convienent.
Anyway...i thought this was the most productive spring break ive ever had,
Theres a couple things i would redo in a heartbeat....i would sand that bondo sown like none other then i would during the wet sanding move up the scale...i was cheap and only bought the 400 wet grit because thats all they had at ace. But yea i definetly agree that it was a great lerning experience, i feel that if i do the whole bondo/paint thing again it will turn out alot better.....you just need some confidence.
Old May 8, 2007 | 11:24 PM
  #119
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
It looks better than it did, but in all honesty it looked like total crap before so that isn't saying much. Props for the attempt though.
BTW, I painted the front fenders and fascia on my RS with a couple of rattle cans and it turned out really good for a 'temporary' paint job until I get it painted for real. And I used Dollar Store paint so the whole thing cost me like $5! I did the headlight pockets too.
Before:
During:
After: (got the fiberglass hood after painting)
Old May 9, 2007 | 10:02 PM
  #120
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Wow, looks like it matched really well at least.
Old May 16, 2007 | 10:55 PM
  #121
83Chevy__Camaro's Avatar
i would have just saved more money and did it right, now your going to have to undo all that crap to make it look right, you just made a lot of work for yourself in the long run.
Old May 17, 2007 | 12:05 AM
  #122
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
wow! that looks very nice for $25
Old May 17, 2007 | 08:17 AM
  #123
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Isn't it time to close this thread instead of having it ressurected week after week with the same boring arguments? The kid did a good job with what he had. Let's leave it at that.
Old May 17, 2007 | 06:00 PM
  #124
koolbreeze92's Avatar
Car: 1992 Brilliant Red Metallic with T-
Engine: LB9 305 TPI
Transmission: MD8 4 Speed Automatic
Axle/Gears: 2.73....Paint peeler
lmao.....
Old May 17, 2007 | 06:33 PM
  #125
Its not an argument, its the fact of the nature. Its **** like that that gives people more reasons to make fun of 80s camaros. If your going to fix a car up do it right, not some half *** alabama shade tree hick job done by cletus, im sick of seeing people abuse these cars and doing half *** repair jobs, giving the whole god damn generation a bad name because of the broke *** cletus and jeds that trash these cars and paint them with a mother ****er ROLLER, you have got to be kidding me.....
Old May 17, 2007 | 08:27 PM
  #126
Engine: 305 TBI
your being completely irrational
Old May 17, 2007 | 08:38 PM
  #127
j dezzy's Avatar
Car: 87 TA
Not trying to be a *****...but there are ways of getting your point across that don't involve cussing about the kid because he did his best with what he has...not everyone can afford to have the work done on there cars...does that mean that they don't deserve to have the car?
I kinda agree that this thread should be locked though. all points have been made. if anyone comes along with a questions they can always PM...
Old May 17, 2007 | 08:42 PM
  #128
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
FYI, The current Hot Rod magazine has an article on this very subject. They paint a 63 Falcon. Of course, in pictures it looks pretty good, but I'd have to be dirt poor to even think about doing it to any car I owned.
Hate to see this thread come up again. Even sadder to see Hot Rod filling pages with it.
The times, how they have changed!
Old May 29, 2007 | 12:11 AM
  #129
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
I'd say he did great... when i was 16 this is what my first camaro looked like.... dollar store primer. looks good due to custom ground effects not matching...
Attached Thumbnails Final Results From Extremely Poor Man's Paint Job-149-4970_img.jpg   Final Results From Extremely Poor Man's Paint Job-img_7933.jpg   Final Results From Extremely Poor Man's Paint Job-img_7935.jpg
Old May 29, 2007 | 01:07 AM
  #130
AmorgetRS's Avatar
I have closed this thread, PM me with issues.
dustint209
Sep 9, 2015 08:09 AM
oscarfromla
Southern California Area
Sep 1, 2015 12:39 PM
neekolzun
Aug 24, 2015 04:59 PM
kyle5647
Aug 7, 2015 03:08 PM
