TTII 17x9.5 3rd gen offset, do they exist?
Old Apr 12, 2007 | 03:06 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
do 17x9.5 TTII wheels with correct 3rd gen rear offset exist? simple yes or no is all i need. really wasnt sure where to post this because it isnt really a fitment question, just an availibility question
thanks!
Old Apr 12, 2007 | 03:52 PM
BADNBLK's Avatar
COTM Editor
Re: TTII 17x9.5 3rd gen offset, do they exist?
As I remember the 17x9.5 tt2's can be purchased for the thirdgens, but it is not a standard backspacing that they offer, so they consider it a custom build and charge a bunch more for them. When I was still selling wheels the custom built tt2's were a big PITA, and there there no returns, so some shops don't even offer to order the custom back spaced wheels.
Old Apr 12, 2007 | 06:19 PM
rwdtech's Avatar
yeah someone told me they exist, but i couldnt find them anywhere. do u know how much more they are for custom? i just need 2 for the rear. 17x8 is fine up front
Old Apr 12, 2007 | 07:09 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'll sell ya a set 17X8's buddy....you'd never know the difference with the
P275/40's on all fours...
Old Apr 12, 2007 | 07:33 PM
BADNBLK's Avatar
COTM Editor
I think that Chevy High Performance did a suspension wheel and tire article a few years back (maybe like 4), and put a Hotchkis suspension package on a 91-91 z28, then showed the improvement the size of wheels and tires had on G-force readings.... anyways, this article they used 17x9.5 tt2's and gave out the backspacing and offset measurement for front and rear wheels along with pricing (at that time).
I don't know if that article is in an archive here, or anyone else has it, but that might help you, OR you could just e-mail American Racing!!!
Old Apr 12, 2007 | 08:08 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
They are actually a custom order wheel indeed. I just mounted a pair on the rear of my car. They are 9.5 with a 5.5 backspace. You can find them at Summit.
Old Apr 13, 2007 | 06:30 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Also looking for TT2 17"
From what I have found here on thirdgen
Rear: 17*9,5 5,5"BS 6.0 mm Offet (+?)
summit ARE-C4057956155
Front: 17*8 4,75"BS 0 mm offset
cant find them at summit?
Old Apr 13, 2007 | 07:41 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
considering that virtually every RWD GM vehicle from the 80s and back used the same offset wheels, it really disappoints me that these aren't one of their standard offerings. Everybody slaps the 8" wheels onto their muscle car instead of the wider stuff. Although I have to admit, that I like the "fat tire" look of a 275 on an 8" wheel better than a 275 on a 9.5" wheel.
Old Apr 13, 2007 | 08:01 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
I had to custom order mine when I got them. If you are running 9,5"s all around - be sure to double check your clearance between the inside of the rim and tie rod. I would've had conflict on mine if I had gone 5.5" up front - so I went 5.25" front and 5.5" rear.
Also, if you have - or are planning on - a C5 front brake swap, the spokes of a 17" TT2 wheel WILL conflict with the calipper and requires modifications to the calipper and/or spacer. So you'll need to compensate for that on your backspacing if you are gonna have a 17" TT2 and C5 brake combo.
Ken
Old Apr 15, 2007 | 02:20 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
That was on a maroon RS, with Vintage Wheel Works V45 whee. It was sexy as hell!!!!! They used 17x9.5s on all 4 corners. I can't find that mag anymore though...lost it
Old Apr 15, 2007 | 02:23 PM
rwdtech's Avatar
the 9.5 inch wide wheels are so expensive!
Old Apr 15, 2007 | 07:50 PM
BADNBLK's Avatar
COTM Editor
NO not the one I was talking about, but I do remember that car... Tbi with some real grunt. The article I was talking about was much older than that, and it was a black 91-92 Z28, probably dating myself here.
Old Apr 15, 2007 | 10:00 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It was Chevy Hi Performance article called "Zig Zag & Drag" where they Bilistines and all hotchkis syspention. TT2's and the car pull better numbers than C5s and low end Ferarris. I think the only one it didnt beat was a viper.
I have both mags still...
Old Apr 15, 2007 | 10:19 PM
BADNBLK's Avatar
COTM Editor
Yup that is the one!!! Pretty sweet numbers from a third gen!!!!
Old Apr 15, 2007 | 10:21 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Uuuhhuu, This will show my age also... When they did that Mag. 1st Thing I did was called up Summit Racing and ordered EVERYTHING they had on the car for suspention. The Only diff road I took was Koni's instead.
Now Im gonna have to dig both of those mags out. just to check it out again.
Old Apr 15, 2007 | 10:50 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
and when you do, scan them and post it for everyone else to see too!
bjpotter
Jan 22, 2019 12:27 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
