Favorite plastic polish???
Old Apr 19, 2007 | 10:51 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
What is everyones favorite polish to do your tail lights with??? Am going to give it a try this weekend...Thanks, Tom
Old Apr 19, 2007 | 11:29 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Favorite plastic polish???
3M
Old Apr 19, 2007 | 11:56 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Old Apr 20, 2007 | 07:06 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks.......................
Old Apr 20, 2007 | 07:17 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Flitz
Old Apr 20, 2007 | 09:39 AM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
I've used meguires plastic-x. it worked good for cleaning my tail lights and headlights, because they were hazed. id still like to get them cleaner.
Old Apr 20, 2007 | 10:07 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Meguillars has a nice plastic polish that removed the haze from my car.
Old Apr 20, 2007 | 10:16 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
When I did mine, I went a little bit more hard core. I sanded them down quite a bit, repainted the black gridlines and gave it about 7 coats of clear and then used meguires buffing compound to make it perfectly flat (get rid of orangepeel etc). In my opinion, they turned out perfectly and look a million times better. I have used meguires plasic x on my parking lamps and it did a good job, but it isnt comparable to what I did to the tail lights. It took me about 60 hours of actual work to get them done though because I wanted it to be perfect.
Old Apr 20, 2007 | 11:33 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I used the 3M Plastic Polish (ordered it through O'Reillys) on my t-tops when I wet sanded them and I used it on my uncle's Impala's headlights and taillights when I detailed it a few weeks ago and the stuff did a really good job. I need to find some 3000 grit sand paper and sand my t-tops again though to get rid of the 2000 grid scratches.
Old Apr 20, 2007 | 03:23 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
i used novus 2 step on my taillights. no idea where i got it from but it did a good job
Old Apr 21, 2007 | 12:15 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
I used 3M and Mothers. The 3M worked better and also you will have better results with a soft buffing wheel to apply. Terry cloth off and final wipe with a super-soft rag, flannel. 3M also makes a cleaner if they are really hazed. Use a medium buffing wheel to apply it and then do the afformetioned 3M polish.
Old Apr 21, 2007 | 02:44 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Flitz is the best stuff I have used. It works on everything, including plastic & paint. Spending 60 hours polishing your lights is a little overboard IMO. I just finished a set of tailights for my cavalier and it took about an hour and a half for the whole thing. Use 400 grit wet sandpaper to remove the DOT numbers and any scratches then use 1500 grit wet to remove the 400 grit scratches. After that I use flitz on a rag and hand rub it to get it pretty close and then I used plastic polishing compound with a soft buffing wheel on a electric drill (both from Ace hardware) to get them to really shine. I've tried going further with plastic before, going to extremely fine grit sandpaper, trying all different rubbing compounds, etc and there is no noticeable difference between doing that and the steps I described above. The time spent with the buffing wheel is the most important and taking your time and not staying in one spot too long (builds up too much heat) is the key.
Old Apr 21, 2007 | 09:11 PM
Double C's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Transmission: TH-700R4
I use Meguiar's PlastX Polish and get good results. I use a good soft polishing cloth and a lot of rubbing. Turns out real good.
Old Apr 21, 2007 | 10:00 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Anyone using the power ball to do the tail lights.??????????..I tried some 3M the other day with a drill and buffing wheel, but I guess I was not doing something right...So I got a rag, and tried that still did'nt do to good...I guess it just takes some practice...I am going to work on them some more this week.....
MrPackstin
Oct 25, 2017 08:09 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
