Cleaning Front Parking lights
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Re: Cleaning Front Parking lights
get under the front of your car on your back. there are two bolts per parking lamp. one is easily accessible since its lower then the other one and you can just use a ratchet to get at it. the second one is a bit harder, you have to stick you hand up and around a piece of plactic that connects to the front ground effects. good luck!
