Vertical / Lambo doors are on!
Car: Mazda Protege5
this is a universal weld on kit i got off of ebay. the doors stay up in any position you put them in.
yes it can be done and no the doors arnt too heavy.
ok here are some more pics, i still need to cut off the lower hinge but im not in too big of a hurry:
of the back of the hinge. is this what you wanted Tobias?
this is of the whole assembly:
this is how far you can open the door (and have to in order to clear the fender) before you go up:
and a couple of the shots from tonights little photoshoot:
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Vertical / Lambo doors are on!
I wont lie, It looks really good. I think it may just be your car though
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
I was gonna say the same thing dave. What kit is it exactly and what did you pay? I hate small parking spots.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
looks interesting, though I'd never do it
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks pretty cool. got any pics from the rear looking forward, of the hinges?
Car: Mazda Protege5
http://cgi.ebay.com/ebaymotors/VERTI...spagenameZWD1V
these are pretty much the same ones.. just a different seller. same hinge with 2 150 lb struts per hinge. i paid 450 shipped so these are actually a bit cheaper
the door does open out first. then up. you have to open it out to clear the fender when you go up.
ill get more pics up later today and show you what the set up looks like and how far you can open out before up.
thanks for the compliments guys!
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
That looks great, if I can ever afford to get another Z28 or Iroc thats what Im gonna do. I like the look and noboby around really does any mods where i live. Great Job. Keep us updated on the long run on how they do over time.
I think the doors always look cool when they're up like that. I get what abubaca is saying and I don't like how you have to open them normally first. My plan was to get a GT Factory gullwing kit, a strong enough shock that it would just lift the door up, and then wire up a remote door popper to have the doors just come up and out. Then shave the handles and locks. I'd have to get a photoshop to see how it would actually look though.
It'll probably never happen though, I cant see spending 1000 dollars on door hinges when I want a ls7 so bad...so uhm, yeah it looks cool, thumbs up!
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
man they do look good.
they look a lot better then i thought they would.
it doesn't hurt that you have a sharp looking car either.
GOOD JOB
GOOD JOB
I get what abubca is saying and I don't like how you have to open them normally first.
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
To be honest, it doesnt look all that bad, im am a bit concerned tho of how much they weigh... I think these doors are a bit heavier than they should be...
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
I had a set on my old car...
I won't do it on my Trans Am, but it does look like you did a good job. Enjoy the looks and double-takes you get when you throw those doors up
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I saw a camaro in a hotel lot the day after the Hot Rod power tour was here. Even though it was 7am and I was in my work van, it cought my eye enough to dig out my camera a take a (apparently) horribly low res picture.
I personally wouldn't want it for either of my cars but, it's certainly an attention grabber... ( I wasn't quite prepared to be taking picture that early in the morining, though, even on a beter setting, it wouldn't be a much better picture)....
Actually, I prefer the half out, then up door. It allows for a LOT more regular use, but yet has the loud boisterous in your face look for shows etc. etc. I ran into a guy at a local show that had 'em on a new Charger and he said he NEVER used the lambo action unless he was at shows. He said it got old after a few days!!!
Oh, I like them the other way more. I don't really drive my car every day, and when I do I never park near anyone, so I just think it would be awesome if I could walk up to my car, push a little button on a remote, and have the door pop up as I'm walking to it. Check out these pictures, they're exactly what I want.
http://www.gtfactory.jp/flgtfgal/gul...allerymenu.htm
If I had to daily drive it and park next to people (I don't even know if those clear my garage
) I would rather a door I could just open normally though.P.S. Sorry I got your name wrong there, missed an "a"
Car: Mazda Protege5
yeah thatd be pretty sweet. but i like the fact of putting the doors in any postion and them staying there.
anyways. new pics are up.
thanks for the compliments!!
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Looks pretty cool.
What's it like if the wind is blowing hard?
Car: Mazda Protege5
id imagine they'd sway. but thats the beauty of not having to have to put them all the way up. so on a windy day you can leave em down and just swing them out. of lift em 45* and still have plenty of room to climb out. ive done this several times. and i installed the struts on a day with wind. i was a little concerned. but you need the doors 90* up in order to install the struts. i wouldnt leave them up in strong wind.
hey udamon, did you remove the top hinge from the door? They are welded on. It looks like you would have to drill the weld, remove the hinge and then maybe reinforce the metal on the door? Is that what you did?
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Not really feeling it. That's close to $500.00 you could've spent to make your car faster.
Car: Mazda Protege5
i did remove the hinge. i didnt cut the weld though, i left the back of the hinge on the door. just cut along the top and bottom till flush with the door.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I always wanted to do this to my Trans Am and since I have installed a few of those GT factory kits which I think are one of the best on the market.Im not sure how well they suit our cars since its a long door and some cars just dont look good with lambo hinge kits in my opinion but i like how yours turned out.
I do have a few questions with the installation process with your car as far as clearencing the fender and how much you limited the travel of the pivot arm as far as swinging outwards and for how much the door goes up...are you very close to rubbing while going up with anything.Is the kit welded on or did you just bolt it where possible.On cars we do at my shop we spend a few days making it a bolt on kit and try to keep the car able to return to factory including wires so im just curious.looks like a clean job on your car
Oh..dont be afraid of wind with that kit..ive tested how strong that thing is even while moving and it barely budges..and those shocks are nice..they assist in lifting the door at a nice rate and easily be pulled down with a finger.on compact cars that ive done..the shocks would actually lift the door all the way up after being swung open which looked cool.
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
i like it alot i was thinking of doin it one day
Car: Mazda Protege5
these were welded on. the key to clearing the fender is mounting the hinge AS HIGH AS POSSIBLE on the car. every little bit helps. i also had to cut the inner fender support off to allow the hinge to swing out as far as possible. then i put the fender on and opened out the door as far as it would go before hitting and held the door there while my friend took the fender back off and set the setscrews in to limit the swing out distance. i didnt need to set any limit to how far up they swing. then can go all the way. but you do have to set how far it swings back down. because the doors are so heavy then when you open it, they just drop. so you have to adjust that screw just right to where the door closes fine. doesnt take much. thats about it for adjusting. and when you got all that done you have just enough to clear the fender but the weatherstrip on the door does rub in a section about 4 inches long when it swings up. but with the struts on they want to push the door closed while its open so you have to hold the door out while you swing up. or the whole thing will rub on the way up. its a little tricky getting in and out at first but you soon develop a simple routine.
as far as flexing where the hinges mount. it seems pretty solid but i did weld in some reinforcement plates that also provided a flat mounting surface on both sides.
thanks for the comments guys! you gotta love the looks you get from everyone when they see it!!
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Never really was a fan of those. The biggest problem I had with them was the price. Just not worth it, to me. Now, that I see it on your car I am amazed that it looks as good as it does. I am liking it. Very good job.
Still, until they drop under 100 i am not buying them.
I have a "lambo" roof, it folds and dissapears.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It looks really good, but I am really concerned about the all of the weight of the door on that one top hinge. These doors are kinda heavy.
Car: Mazda Protege5
thanks! usually this isnt my daily driver but an old man pulled out in front of me while driving my sebring
so while the cars in the shop ive had to drive my camaro. been a week or two now and i still dont get tired of opening the doors up. they are still holding up great.
Car: 1987 Camaro
Engine: 5.7
I haft to say I like, ive though about doing it, but id haft to have someone else install it, but I just dunno
Car: Mazda Protege5
thanks for the comments! i had my girlfriends uncle weld for me. it was kinda a hectic process as we couldnt seem to get the passenger door right. we did that one first and it came out bad... did the drivers side and it came out perfect. then we had to redo the passenger door and now its ok. not perfect but good enough. he charged me 40 bucks. so it cost about 500 total
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
my biggest gripe is the fact that these cars were never made to have 'lambo' doors and as a result, everything that is seen when the doors is open is ugly assembly iusses that represent a mass produced machine on the assembly line(screws, weird paint etc) - whereas this would be smoothed out and look finished on actual lambos.....no matter how good of a job was done to mock up the doors, that stuff alone makes it look like a cheap job.
Car: Mazda Protege5
yeah its definitly ugly under there but i do plan on cleaning it up as much as possible. we'll see how that goes.
i have to agree with this, as much as its cool to see something new done to third gens, the money spent should go towards powertrain not trying to duplicate doors on half million dollar cars that were designed to go straight up not out and up.
Engine: 3.1
I think this picture completely depicts how I feel on this subject...
Car: 1987 Camaro
Engine: 5.7
Well I think it is neat becase you dont see it to often, people like those style doors but cant afford a lambo so its the next best thing. not everyone isnt about making their car faster some people like cars for the show side of it and they def. put on a show.
Car: Mazda Protege5
that honduh has aftermarket wheels too.. shoot and a spoiler.. looks like i gotta take off my 18s and my spoiler too. shucks.
sameness is boring.. be like everybody else... nahhhh
dont get me wrong hopefully next year ill have an engine in it worth talking about. but untill then whatever takes ppls eyes off the v6 works for me.
i had a sheriff on a motorcycle drive up alongside me and started talking about camaros as we drove down the road haha.
Engine: 3.1
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Not my cup of tea but they look good. Nice job.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
