origional paint color...
Old Aug 25, 2007 | 01:13 PM
GraveDigger's Avatar
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
so i have been told that there is a paint code for our cars on them, however i have not been able to find it, i checked the codes in the center console and found nothing. Am i looking in the wrong place? 89camaro if it helps...
Old Aug 26, 2007 | 11:08 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Re: origional paint color...
the code should be at the lower left corner of the rpo list
Old Aug 27, 2007 | 07:05 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
On the newer cars, its with the RPOs, outside the regular box of numbers and will start with "wa". ie: wa_xxxx
It will be a 4 digit number after the wa.
Also, within the RPOS, it will be a 2 digit number followed by the letter "U".
Let me know what you find. and then we can take it from their.
Leon
Old Aug 30, 2007 | 02:48 AM
Car: 1989 iroc
Engine: 5.0
Transmission: t-5
so i took a look at the codes and this is what i found...within the RPOs "40U" and in the bottom left corner i found "wa-L8554"
Old Aug 30, 2007 | 09:24 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
http://www.chevy-camaro.com/chevy-ca....asp?year=1989
Old Aug 30, 2007 | 11:36 AM
1tinindian's Avatar
Thats it, you've found it.
Both numbers varify that you have a while car.
Leon
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
