Check these babies out $50 for 4
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Check these babies out $50 for 4
i'll take a set for $50, let me know where to write the check.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
wow nice score, lots of elbow grease too.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Car: 83 Z-28
Engine: 305 Qjet
the rims came from a friend, they were actually free, i cut some wood for him. the $50 was for the sandpaper, tal-stip and pollish
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I spent $100 on my pair of fronts (They'll look good in the back when I get rubber put on them). $50 on the two rims and $50 on supplies. I bought like 3 different kinds of paint stripper and none of htem took off the most stubborn chunks. I had to hand sand a lot of them out... ugh.
I got them half stripped already, the guy I bought em from had planned to polish them but I think he decided he just didnt have the time for it and gave me a good deal on em.
I think you need to go back over it with some really low grits, I can still see some of the machining grooves there. I know it's a pain and it takes forever but sanding those out really makes it look good.
Here is the progression of my wheels:
This is after stripping most of the red paint off and hitting it with some 220 grit.
Heh, you can see all the aluminum dust all over the place. Wet sanding doesnt get rid of it entirely I guess. Couldn't have been good to breathe that in, but whatever...
I went back the next day and decided I needed to get rid of those machining grooves, went down to 150 grit and spent at least an hour per rim with that.
Then the same with 220, then with 340, then 420, then 600 I think. Remember, the more time you spend with those heavy grits, the better it's goig to look when you're done. Let the heavy grits work for you, sand until you're sure that's as smooth as it's going to get with that grit, then move on.
This is how they turned out after 600 grit and final polishing. I personally think I'm going to go back to 600 for a while longer sometime soon and go over the lip (I ignored them this time around). The smudges you see in these pictures are actually finger prints, the polishing looks great, I just think I can get the reflections a little clearer with a little more elbow grease.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I agree. You want absolutley no machine marks. Mine came out perfect. Stripping them is a pain. Sanding is a pain. Don't be in a hurry to polish. It's like painting a car. If the prep is not right the finish won't look good.
And I would strip those caps too because polished rims with messed up caps won't work.
Keep at it. It takes time to get a perfect set of polished rims.
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
polish, and then paint body color. I really liked it because they did it from the factory on the white and red 91-92 Z28's but they never did it on the blue ones. everyone always thought it was a factory deal.
before and after.
before and after.
Car: 92 Camaro RS
Engine: 5.0 TBI
Sorry to high jack your thread, but I have refinished my wheels like you all did, but I could not get the center cap to turn out like the rest of the wheel. Is it because its a different metal or what? I did the same procedure to center caps as I did the wheels.
Axle/Gears: Posi
Note the reflection of the ground on the center caps.
Car: 92 Camaro RS
Engine: 5.0 TBI
The plastic part is not the problem, it is the metal surrounding the plastic on the center cap.
Car: 92 Z28
Engine: Boosted LSX
Those look great ! I miss my 92 Rims I polished when I got the car. was one of the 1st things i did. I bet I had 40hrs into them back then. I did 90% of it all by hand and a DA. Then polished em by hand with Mothers. Now I know better and use a big ol buff wheel and white rouge.
The metal on the center caps seems to be a aluminum skin and polished up just as good as the rims.
http://www.cecoatings.com/images/CarStuff/92Z/Rims/
http://www.cecoatings.com/images/Car...olishedRim.jpg
http://www.cecoatings.com/images/Car...s/DSC01484.JPG
Car: 92 Camaro RS
Engine: 5.0 TBI
Wow, those look great! I guess I will go over the centercaps again and see if I can get them to look like yours, thanks TPI383.
Car: 92 Z28
Engine: Boosted LSX
Thanks. I forget who it was from this site who bought em off me.
You only need to use 800 or 1200 on your caps depending on consition.
BumpaD82
Feb 26, 2016 02:57 PM
Street Lethal
Sep 7, 2015 01:09 PM
