still sagging and not tight enough
Old Sep 22, 2007 | 01:27 AM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
hi guys, I changed the door pins and found that my door still sagging, the door didn't lock tight enough before, now they still don't, changed the door pins improved a little bit but didn't solve the problem.
I don't wanna buy door hinge, they are too expensive and I have to purchase thru the internet (I am live in Taiwan), is there any other way to do or the problem is not the door hinge?
Thanks a lot!
Joe
Old Sep 22, 2007 | 08:44 AM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: still sagging and not tight enough
did you do upper and lower or just the lowers?
Old Sep 22, 2007 | 09:52 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I have this problem too. Just changed the door pins (upper and lower) too. The problem now is that the actual mount on the frame is bending with the weight of all those years gone by. The shop who did my pins told me the next time was going to require a welder. You may be in the same boat.
Options? Well, I don't recommend anything but the welder but I have heard of gents putting a jack under their door and cranking it up but this sounds like a bad idea to me.
Old Sep 23, 2007 | 02:25 AM
AmorgetRS's Avatar
http://www.top-downsolutions.com/pro...products_id=95
Old Sep 23, 2007 | 04:02 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
I check this product before but my English is not so good so I don't know what it is ? would it solve all the door problem ?? (I don't need to buy any other stuff)
My friend told me I may need to replace the door hinge, and I just replaced the lower pin, I though there is only one door pin each side, is it?
Is there any others parts I should purchase to fix the sagged door ? my body work should be done after fix the door, the door problem is killing me
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
InfinityShade
Sep 18, 2015 08:32 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
