Engine paint choice
Old Sep 27, 2007 | 11:24 AM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Engine paint choice
Aight, pulled the V6 3.1L out of my '91 Camaro and rebuilt the lower end...since I have it out now, I misewell paint it, eh?
It's pretty much all prepped for paint...few things left to do...just haven't decided on a color yet. Any suggestions and why?
Also, any suggestions on a specific brand of paint etc?
At this point, I'm going to either paint it gloss black...or perhaps GM blue. Not sure...
Old Sep 27, 2007 | 11:53 AM
Tampa Hurricane's Avatar
Re: Engine paint choice
What color is the car?
Old Sep 27, 2007 | 12:40 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Blue...it's due for a paint job in a year or two...by then it'll also be time for a engine swap.
Old Sep 27, 2007 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i had mine painted silver, and it came out great. Its a bit different from the usual black/blue/orange, and have had several people think its an aluminum block. Coupled with aluminum heads, its a nice neat looking piece.
Old Sep 27, 2007 | 07:54 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea there is a cast aluminum color that they offer in engine paint, my friend used on his trans, drive line and rear end on a 86 ford ranger, it was a pretty sharp color, looked natural
But chevy orange and blue is always pretty......seen a Ford Pinto with a Grabber Green paint job on the lower end ...BRIGHT to say the least
Old Sep 28, 2007 | 12:19 PM
I think it might look good with color to match the body.
Old Sep 28, 2007 | 12:45 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I dunno, I'd be more inclined for the black engine with polished stuff under the hood. I guess though, you should wait till you get a v8 to do that. I like when you pop the hood and see everything in black and chrome. Looks hot!
Old Sep 29, 2007 | 11:33 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
My vote would be for the sterotypical Chevy Orange or Black...As for the kind, if your looking for rattle can dupli color has High heat engine paint in many colors..
Old Oct 1, 2007 | 06:51 PM
fenton06's Avatar
well, you don't need engine paint. I've used the 69 cent walmart paint before and it's fine, so that opens up a lot more options.
NOTICE: I you're going to flame this, move along!
Personally, I gave my engine a white basecoat with walmart rattle cans, and then proceeded to paint it flourescent pink. No oil leaks are getting away from me...and plus when I pop the hood people double take at the pink...it's priceless! (to me)
Old Oct 1, 2007 | 11:34 PM
pentiuman's Avatar
I went with the black Duplicolor high heat engine paint on my new engine -because that's what it came with originally. (The old engine was so rusted that it had no paint left, so I went to the dealership to discover the original color). Also, that's the color the engine re-manufacturer painted the long block I bought, so I didn't want to change it. Before installing the engine and all the other junk, the engine looked especially great, especially with the brass freeze plugs. Then I painted all the bolts black, the color they were too. Only regret is that I wouldn't have used such a glossy black, as in the wrong light, the new paint can sometimes look like it has an oil leak. Should have gone with a flatter black. The water pump, the valve covers and a couple other items I painted that cast aluminum color (also high heat paint). On the alternator, I only painted the middle stripe part black, as it was, and just cleaned the rest of the metal with a dremel.
Of course, after installing all the junk on the engine, you don't see much of the actual block anymore. Still, it's nice to know that it's clean and looks good. Had to do some touchups after installation scratches and missed areas. I don't know if it's appropriate, but I did the final paint cleaning prep with rubbing alcohol, and wore plastic gloves. Discovered that some parts could be better painted when hung from a wire, or on a wooden dowel rod. Good luck with your project!
Old Oct 2, 2007 | 07:39 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Thanks for all the input.
I think I'm going to go with the aluminum looking stuff for the block and heads...and I'm going to paint the valve covers and oil pan gloss black. I'll post pictures once it's done in a week or so.
Old Oct 2, 2007 | 11:37 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
350 chevy orange with clear coat and lots of chrome and polished headers and gloss black engine bay thats howd id roll
Old Oct 3, 2007 | 06:30 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
chevy orange!!!
Old Oct 3, 2007 | 09:52 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
I like the chevy orange, as well...but this is a V6...V6s are not special enough to be painted such a sacred color.
Old Oct 3, 2007 | 10:02 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I painted my block and heads Chevy Orange, left the oil pan black, and painted the valve covers black, as well as the upper plenum. The lower intake and intake runners I painted aluminum color. I love it. I dunno how chevy orange would look on a V6 though, it seems sorta out of place unless it's a V8. I used dupli color. It says use primer, which I didn't. It has about 4000km's on it right now and there are no bubbles, marks, or anything else. it looks great still.
Old Oct 4, 2007 | 07:18 PM
89RS_82Z's Avatar
lol, i seen a V6 (block,oil pan, water pump, timing cover) in a blazer painted in plasti-cote (or dupli color) engine red (its a high heat engine paint...DUH), its a shiny red, kinda like a fire truck, looked pretty good, heads, intake, and the ***. brackets were in a natural aluminum cast color, like my friend did on his ranger...so that red my look good, but that cast color looks natural and looks real good clean
Old Oct 5, 2007 | 07:36 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Cleaned it and started painting today...
Here's a teaser pic...
I'm very happy with how it looks. Thanks for all the suggestions.
Edit:
And another...of just the valve covers and the oil pan being painted...
Old Oct 5, 2007 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
silvers and black i see, very nice choice
Old Oct 5, 2007 | 07:52 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Thanks for the compliment...
It's aluminum, technically...It looks more like silver in the pictures.
This gives you a good idea of what it looked like before...It was being degreased at this point...
Old Oct 16, 2007 | 10:08 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Dropped it back in today...
Old Oct 16, 2007 | 10:12 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
That thing looks brand new. Congrats on a job well done.
Old Oct 17, 2007 | 10:06 AM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
That looks awesome. I'm building my new 2.8 next week and dropping it in; I hope mine comes out as good as yours.
Old Oct 17, 2007 | 11:21 AM
helly's Avatar
As I get to building the engine for my Formula, I think I'm going to paint it all black except for the heads/valve covers, which will be red. Ought to look pretty mean.
Old Oct 17, 2007 | 03:18 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Thanks for the compliments...I really didn't put too much work into it as I'll just be ripping her out and putting a V8 in sooner or later...but I'm still very pleased with how it turned out. She should be running again by tomorrow.
Old Oct 17, 2007 | 03:44 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
wow that looks great, it almost looks new.
Old Oct 17, 2007 | 06:19 PM
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Thanks again...
She's back in now...finished up everything under the car. So, she's sitting on all fours again for the first time in 6 weeks. I just gotta hook up a bunch of stuff under the hood yet...she'll be running again by tomorrow afternoon.
Yea, I know...my engine bay isn't the prettiest thing in the world.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
