QUESTION ABOUT IROC WHEELS!!
Car: 1994 Chevy Blazer S10..1990 Camaro
Engine: Blazer - 4.3L..Camaro - 3.1L
I am planning on buying the chrome Iroc Replica wheels for my 1990 RS. I wanted that "muscle car stance" to it, where the front sits lower than the back. I was wondering if putting 16s in the front and 18s in the back would be too drastic, or should I put 17s in the front?
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: QUESTION ABOUT IROC WHEELS!!
I would not recommend raking the car by changing wheel sizes. Most people off set their tires by one 1" (17 front 18" rear). To rake the car you would have to put a smaller tire height on the front.
I would suggest using springs to lower your car.
Not sure why you want the front lower?
ok, thanks. The reason I asked is because I have seen people use different size rims. In their case, it was 18s in the front and 20s in the back, but I dont want to go that big. I don't want to lower the front, I was just explaining how the car would sit. I want the back raised. (hence the 18s in the back) and I have 15s on it now, so I wouldn't be lowering it at all. What would be the ideal tire size to acheive this?
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
If you feel you must do this then do as the above poster suggested and go with adjusting your stance via the springs not the rims.
However the car is yours to do as you please. Just remember as you tour this site...if you don't see a lot of people with high post counts doing it...there is a reason why?
Thanks for the info. I didn't have my heart set on doing it. I just loved the way it looked, and like I had said, I've seen people use different size rims so I figured I'd ask. It will be my daily driver soon once the winter comes to an end, so in that case, I won't do it. I think I'm leaning more towards putting 17s on.
Go for it ... especially if you like the look. I would use blocks in the rear rather than lower the front.
My little bro just did this to his and it looks a lot more like a muscle car, and less like a cruiser.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Moog IROC-style replacement springs, 5665 and 5662, will provide a slight rate (26 3/4 front and 28 1/2 at the rear). I didn't like the fender gap in the rear so I remove the OE isolator and replaced with radiator hose. By so doing, I lost a half inch. The ride is quite nice.
JamesC
JamesC
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
The best 'muscle car' stance is with the 2nd gen Camaro, not the 3rd gen- sorry.
The 2nd Gens looked better because they APPEARED longer than the 1st Gens, so a slight nose down, nasty hood scoop, big slick rear attitude said don't FWM!
With the big slick/skinny Crager front tire look, it said 'I have a monster engine under this hood and when I step in it, GOD KNOWS where this beast is going!!
Pro Stockers from the 1970's like Grumpy Bill Jenkins, Wally Booth etc had some really NASTY looking attitudes with their cars, but the 3rd gens look better as road racers- a SLIGHT nose down look is good, but I think that it needs to be balanced with a SLIGHTLY wider look at the wheelwells. Just my opinion...
mustangman65_79
Aug 11, 2015 03:17 PM
