Hatch light?
Old Nov 16, 2007 | 11:31 AM
89Formula3's Avatar
Car: 91 Firebird
Transmission: 5 speed
Hatch light?
I replaced the bulb in the hatch/trunk of my 91 bird but it's still not lighting up. Is there a connection for it? I've looked around but I don't see anything there.
Old Nov 16, 2007 | 05:21 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Hatch light?
mine did this, take that back plastic off and follow the wires, and just make sure the connections are tight, espically (sp?) the ones that connect to the light itself.
Old Nov 16, 2007 | 07:16 PM
89Formula3's Avatar
Car: 91 Firebird
Re: Hatch light?
Theres nothing like that on mine my car has no options at all could it be that they left that out aswell?
Old Nov 16, 2007 | 07:30 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Hatch light?
hmm, maybe its different on 91-92 models, somebody else will probably have an answer for you. may have better luck in the interior board or the electronics board.
Old Nov 16, 2007 | 07:45 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Hatch light?
maybe someone replaced the plastic trim and used one with a light on it and your factory one didnt have a light, this is if the birds are like the camaros, also if someone removed the hatch pull down (if yours came with it from the factory) the light will not light up anymore, use the RPO decoder on this web site to find out your had the pull down motor and the extra interior lighting package
here is the RPO for the light (89 camaro)
U25 LAMP, INTR, RR COMPT, COURTESY
i think the RPO for the pull down is actually under 1SD OPTION PACKAGE 04(or something like that)
otherwise take it apart and check wires for power and good ground with a multi meter or test light
Old Nov 16, 2007 | 09:20 PM
89Formula3's Avatar
Car: 91 Firebird
Re: Hatch light?
My bird came with nothing no hatch cover, pull down motor, the car is all original I bought it from the original owner so Im 100% sure nothing from the interior was replaced.
Vintageracer
Jan 10, 2020 05:33 PM
hydrolic144
Sep 8, 2015 06:55 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
