rear lights removing scratches
Old Nov 24, 2007 | 03:01 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Need advise on removing scratches from rear lights.
Old Nov 24, 2007 | 11:58 PM
86irocterror's Avatar
Re: rear lights removing scratches
if they are not bad scratches there are a few kinds of plastic polish that helps with fine scratches. i forget the name but its mothers that i have, its in a white bottle and is a liquid. then there is different buffing compounds for plastic that you can use a buffing wheel to do the deeper scratches. but beeeeeeeee veryyyyyy careful and take as much time as needed to do this. its easy to mess up the plastic if you dont be careful. my friend just did his tails on his GTP and they look like glass!!! but his car is black and is now thinking of smoking the lights a little bit....lol
Old Nov 25, 2007 | 09:03 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Meguiars PlastX works pretty good for removing fine scratches.
http://www.meguiars.com/?clear-plast...Cleaner-Polish
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
