cleaning painted iroc rims
Old May 29, 2001 | 09:40 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
I have the gold accented iroc rims and they are a little stained(fronts are darker than the rear). What would be the best cleaner to use? Ive tried the usual sprays just curious what others have used.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s. Chip is custom(doing it myself) Just got a 2 1/2 Harwood and soon to be painted.
Old May 29, 2001 | 09:51 PM
82camaro's Avatar
Car: 82 camaro SC
Soak them in undiluted simple green, let them soak a while, then do it again. If it's still won't come off, try to scrub them with a scotchbrite pad(not too hard).
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 29, 2001 | 10:00 PM
RARE-ROC-Z's Avatar
definately an SOS scotchbrite pad, it worked great for mine. and can you leave the tires on with that simple green?
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old May 31, 2001 | 11:15 AM
82camaro's Avatar
Car: 82 camaro SC
Sure you can leave it on. I spray it on the tires, it cleans them as well.
82camaro
Old May 31, 2001 | 03:56 PM
MR. JORDAN's Avatar
1500 Grit sand paper...Honestly the only thing that worked for me....Try it in a small area first.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Exxon Limited
Aug 9, 2015 08:13 PM
