bolt on scoop question
Old Jun 4, 2001 | 11:30 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Ok, i thought I would try this before buying a new hood. I have a 2 inch cowl scoop that is supposed to go onto a hood.
I am assuming bondo it onto the hood right, my question is how to attach it to the hood? rivits? I don't really want them visible when painted.
And should i cut off the area around the scoop where is is just flat? Kinda hard to describe, but a picture is in the jegs catalog in the hood section.
And finally, how would i go about cutting a hole in the hood under the cowl? what tool would I use.
Thanks for any help.
1991 Chevy truck 5.7 engine
Competition Cam 454 lift
Edelbrock Valve Springs
Holley Red Electric Fuel Pump
Eldelbrock Performer RPM Intake
Holley 750 Double Pumper
68 jets front 74 jets rear
Turbo 350 transmission
B&M shift kit
Custom drive shaft
3.73 Rear end
Flowmaster exhaust
No emissions or computer
Grant steering wheel
http://www.fbody.com/members/Camrs89/
Old Jun 4, 2001 | 03:06 PM
ihateallmustangs's Avatar
when i had my L88 scoop moulded to my car they fastened it to the steel hood by rivets. Then they used fiberglass, sanded it down til it was reasonably flat, used putty to fill in the low spots, primed it to check for any noticeable bad spots..and it came out looking pretty good. [theres a pic of my car in readers rides]
after my hood was done i took a high speed dremel and cut a vent 8"long x 12 wide under it and it vents the underhood heat very well.
Old Jul 8, 2002 | 02:14 AM
bluehog67's Avatar
Car: RS
Transmission: 5 speed
Yeah I'm doin it like the guy above with my L88 except I'm going to put it on from the underside of the hood then rivet it on and mud it, sand it then paint. If you just slap it right on top then it will leave a ridge from where the scoop ends, And it won't be flush with the hood. Do ya kinda know what I'm talkin about ?
Old Jul 8, 2002 | 10:02 AM
Camrs89's Avatar
Thanks for the information, but I already put it on. It doesnt look bad, still has some pinholes and such that I just was too lazy to fill
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
