Is it safe to powder coat a serp tensioner?
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I finally got my Eastwood PC kit and spray booth up and running, and now Im FINALLY ready to PC small parts, anything that will fit inside a 30" oven. Im starting with underhood stuff since I already got the motor pulled. I was thinking about the tensioner though. The powder has to cure at 400-450F for 20 minutes. Would this temperature cause the tensioning spring inside to fail or weaken? I really dont wanna take that thing apart, seems to be alot of force held inside that little *****
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Is it safe to powder coat a serp tensioner?
I know they P/C coil springs, so I don't see why it would hurt the spring in the tensioner. All else fails, I think they're only like, $40 at the usual places. Wouldn't try coating the pulley though.
Car: 89 RS
why not? You mean the belt surface, or the entire pulley as a whole? I thought about cleaning up the belt "grooves" on all my pulleys, then taping it off and coating them
EDIT: wait, just thought about the bearing inside the pulley. forgot about that. damn!
Axle/Gears: 3.27 BW
I'm fairly sure you can press the bearing out. I just wouldn't p/c it out of paranoia. I have enough problems with squealing belts. :P
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
As far as Powdercoating where the belt rides, thats how several of the companys sell them. Mine were P/C in the belt grooves and no problems here.
-Greg
-Greg
Axle/Gears: 3.27 BW
Interesting. I was always under the impression that they masked off where the belt rides. Good to know.
Car: 89 RS
thats so weird, I forgot about this post and I jsut saw another post on a PC board about this same issue. Im not sure about our tensioners, but there was a guy who said he PC'd his tensioner and there was a plastic bushing that ended up melting and oozing out. Has anyone taken one apart to verify there is ONLY metel parts inside? Id hate to go on the assumption that you got lucky with yours only to find out that Im not so lucky
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
gscz28, did you powder coat you water pump?
i did mine and the i hade to buy a new one it must of melted something in there, i also did my pullies i think i might take them out again and do them purple.
2012sergen11
Oct 13, 2015 07:38 PM
