all my polished aluminum looks like !@#$
Old Jan 23, 2008 | 03:42 PM
coredevice's Avatar
Car: 1990 GTA
Engine: 383 stroker
My valve covers has some sort of hard film on them. The only thing I could think of is condensation. It looks horrible! I have alot of polished parts under my hood, and they are all getting this nasty film on them. Is there any type of protector I could put on them to keep this from happening? Also, how does the spray polish work? I am scared to use regular wax because I don't want all the dust with the motor compatment painted black. Can you suggesat a brand or a better way?
this is what it looks like clean
https://www.thirdgen.org/forums/engi...-car-what.html
Old Jan 23, 2008 | 04:32 PM
AMigs87IROCz's Avatar
Car: 1987 Iroc-z
Engine: Swapped into a 350TPI
Transmission: T-56 Six Speed
Axle/Gears: Moser 12 Bolt 3:42 Gears
Re: all my polished aluminum looks like !@#$
Professional advice: If you don't have a cordless drill...get one. Use the mothers mag and aluminum polish with the Mothers polishing mini-ball. You COULD polish them by hand...its a ....yea. But the key with chrome/aluminum is polish-polish-polish
Old Jan 23, 2008 | 04:55 PM
coredevice's Avatar
Car: 1990 GTA
Engine: 383 stroker
will that stop it from happening if i do or make it easier to clean
Old Jan 24, 2008 | 02:09 AM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
the key is to keep everything clean, the problem with polished items is they need a clear coat to stay nice and polished. otherwise they tarnish. i recommended the mothers ball aswell.
Old Jan 24, 2008 | 07:50 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
zoops is supposed to work really well to prevent the tarnishing. or repolish all of it and powdercoat all of it with clear.
Old Jan 24, 2008 | 08:00 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Do you have the car in a garage, next to your winter beater?
Old Jan 24, 2008 | 11:27 PM
coredevice's Avatar
Car: 1990 GTA
Engine: 383 stroker
not next to my beater but yes in the garage. I have a HD2500 GMC Duramax....garage isn't big enough.
Old Jan 25, 2008 | 05:51 AM
Kevman's Avatar
Engine: 2004 LQ4
Well, we found out a while ago with our old car that when you park in the garage (Even if it is not heated) with your snow/ice/salt covered vehicle that when the water evaporates it is similar to an ocean breeze. It's just minor amounts of salt, but the edelbrock valve covers, carb, and the aluminum wheels are completely covered over by a white film.
Old Jan 25, 2008 | 06:27 AM
coredevice's Avatar
Car: 1990 GTA
Engine: 383 stroker
well although I have a single bay garage for my car I think that is the most reasonable explaination. I have my driveway salt stored in there with the car. Here my next question, I dont mind cleaning it over and over....in fact I enjoy it. If I put a sealer on it and keep re-applying say every 2-3 weeks do you think that will stop it. Nothing has oxidized yet but I will do anything to stop this from happening.
Old Jan 25, 2008 | 06:58 AM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
I have found that .. after polishing the aluminum .. I go over it with windex. It seems to help prolong the shine...
Old Jan 25, 2008 | 08:37 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Polish up with the Mini... then...
http://www.rodgear.com/
FAQ about ZoopSeal
http://www.rodgear.com/zoopseal_FAQs.htm
Old Jan 25, 2008 | 09:24 AM
Kevman's Avatar
Engine: 2004 LQ4
For the winter you could just shoot it with a nice coating of WD40. It's cheap, and easy to power wash in the spring.
Old Jan 26, 2008 | 01:39 PM
Car: 1987 Iroc-z
Unfortunately....this will become "routine maintenance" for your wheels...a tip of detailers advice....after you have polished the wheels...WAX the wheels themselves. Use ANYTHING carnuba...not a polymer wax...that won't work.
BE CAREFUL of the windex...only based upon its checmical composition. Windex has ammonia-or a vinegar base...which is acidic...in the recon shop we use that stuff to strip wax/buff material OFF the paint...so be careful.
Old Jan 26, 2008 | 01:52 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
as Amigas87 said use a CARNUBA WAX once you tough them up.
I started using this stuff and its AWESOME.!
POR15 Glisten PC over polished parts.
To clean off polisning residue I use Extreamlly hot water and dawn dish soap. Try ASAP.
Linson
Oct 24, 2025 02:00 PM
bigjay89gta
Oct 15, 2015 08:04 AM
