What kind of clay is in the clay kits??
Old Apr 13, 2008 | 09:06 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I had the meguiars clay kit for cleaning my paint surface. It includes some detail spray and a small peice of semi-soft clay. It works great, but i lost my clay bar. Can i just use modeling clay? I don't feel like spending $15 for a bottle of detail spray and a hunk of cheap clay.
Old Apr 13, 2008 | 09:33 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: What kind of clay is in the clay kits??
I wouldn't risk it to save $15. I'd go to Autozone and get some Clay magic. Should be a little cheaper and works great.
Old Apr 14, 2008 | 11:28 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
No, they are not the same.
Down at TP Tools, they had JUST the clay (bigger bar, different grades) for sale. So they do sell them seperately.
Old Apr 14, 2008 | 09:13 PM
badredbrd89's Avatar
Yeah, those things are NOT the same you use for modeling. There are more than one kind as well. (Mild, Aggressive, etc.) One thing to realize is if you ever drop the clay bar on the ground, discard it IMMEDIATELY. You will NOT get all the garbage out of it that winds up in it. Trust me .
You should be able to do your entire car around 3-4 times depending on the dirt level before needing another clay bar. And dont throw the old one away-use it for claying your glass-it works wonders! Have fun!
Old Apr 17, 2008 | 11:47 PM
popballz's Avatar
Car: 89 firebird
will a clay bar take overspray off my paint? its all over the car and i dont really know what else to use.. also what type should i get? and do i have to wax it afterwards?
Old Apr 18, 2008 | 01:18 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yes, a clay bar should take off overspray. It also takes off wax, so yes you'll have to wax it afterwards. Also, the name is misleading, a clay bar doesn't actually contain any clay at all, it's all synthetic.
Old May 13, 2008 | 10:24 PM
1LE Collector's Avatar
Depending on how severe the paint overspray is will determine what clay too use.The red or purple is around 1750-1800 grit.The grey or blue is around 2100-2200 grit.The clay will scratch the paint surface.White paint will not show scratches if you use the grey clay.It will not remove the wax but if paint is black,green,blue or a dark color I would recommmend a machine polish afterwards.A polish/Glaze then a good carnuba wax.Remove overspray from windows with #0000 steel wool & adhesive label remover for window trim.This should make your vehicle look close to new again!
Old May 13, 2008 | 11:39 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Hi there, new guy.
Where be da pics of the shiny 1LE's?
Old May 16, 2008 | 07:37 AM
Just posted one on ebay.The 89 needs a slight resto.SOLD the 91 & 90.Should post pics of the 1992 sometime.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
neilb
Sep 15, 2015 05:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
