The hood is here...
Old Jun 11, 2001 | 07:21 PM
RealDeal's Avatar
The hood is here...
Ok, my Twin Turbo, finally arrived today, and i want to get it on as soon as possible. I know i have to sand it down to make sure it fits correctly. It also said to put it on the car, because the shipping may have caused some distortion of the fiberglass, so it has to be exposed to sunlight and the running of the engine. Anyway, does anyone have any tips as far as installing the hood? By the way, i'll try to get some before and after the paint job pics. Thanks
Old Jun 12, 2001 | 06:47 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
IT IS NOT TOO HARD OF AN INSTALL JOB. TAKES ABOUT 30-45 MINUTES INCLUDING REMOVAL. DON'T NEED THE ENGINE RUNNING. I PAINTED MINE OFF THE CAR. SEEMED LIKE LESS CHANCE FOR OVERSPRAY AND STUFF. ALSO USED SOME KIND OF SPECIAL URETHANE PRIME ESPECIALLY MADE FOR FIBERGLASS OTHERWISE I WAS TOLD IT WOULD HAVE LOOKED DULL. LOVE THE TURBO LOOK. ONLY BETTER HOOD IS THE NEW THIRD GEN SS HOODS.
ONE CAUTION: TAKE YOUR TIME AND MAKE SURE IT IS BOLTED GOOD AND THE HOOD LATCH LOCKS. EVEN AFTER YOU OR SOMEONE ELSE DOES OIL CHANGES AND THE LIKE. GLASS HOODS WILL FLY BACK VERY EASY IF NOT LOCKED PROPERLY!!
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Old Jun 12, 2001 | 12:12 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Not flamin, but is it always necissary to post pics of your car with your post? You seem to do it quite often.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
Old Jun 12, 2001 | 08:51 PM
ImportsRsloths's Avatar
Man you need ground FX in a bad way, what is that a Sport coupe.... anyway, even though i just ....ed you off, ill sell you my jet black 88 Iroc ground FX when i get the 91 92 Ground FX
Old Jun 13, 2001 | 12:23 AM
Sharky's Avatar
Ground effects? who needs them, all they do is look pretty and creat more air resistance.
If your lucky your fiber glass hood might not need any sanding at all, except for the turbo holes. Mine fit in perfect on the first try, I only had to adjust the attachments twice and I was done.
The Twin Turbo is a sweet hood, I like watching the heat vapors escape when my engine idles at a stop light. Anyway, one other thing I did with the hood was put metal wire over the holes on the inside of the hood and attached it with epoxy(bad spelling). That way small animals and other objects won't fall into my engine compartment.
Lastly, I was curious if anyone has every tried putting a hood scoop on fiber glass.
Drew Veeneman
87' Camaro
Jasper Class II 350 (.3 over)
Stock auto 700r4
Snail like 2.73 gears
K+N Air Filter
Road Demon 625cfm
Edlebrock Performer Intake
Edlebrock headers
3" Cat+Flowmaster
Ugly olive drab camoflauge paint job
Check Out Sharky at https://www.thirdgen.org/rides/index...ew&rideid=3002
[This message has been edited by Sharky (edited June 12, 2001).]
Old Jun 13, 2001 | 12:51 AM
RealDeal's Avatar
Thanks, i was gonna ask about the holes, and what i should use to keep unwanted objects from getting in there, lol. Anyway, do you have any reccomendations as far as to cutting the holes? I want this hood to be perfect. Any suggestions are appreciated. By the way, i love your car. The paint job is by far one of the most original i've seen.
'91 Camaro RS (Purple!)
K&N Filter
Awaiting my Twin Turbo Hood and Flowmaster.
Old Jun 17, 2001 | 01:06 PM
fast.as.fuc's Avatar
Yeah i was wondering also about putting a hood scoop on top of an aftermarket hood like the ram air hood for firebirds.
Old Jun 17, 2001 | 07:37 PM
One Eyed Jack's Avatar
wow that camaro without GFX makes it look more muscular
1992 Pontiac Firebird (stock)
- 305ci V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
