Ok to paint Engine?
Old May 25, 2008 | 07:43 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
Ok to paint Engine?
Hey guys i got a 305 i just cleaned and mostly all of the paint is coming off of the intake manifold and valve covers, water pump ,etc. would it be ok to paint it with engine paint to make it look a little better if i masked everything off and maybe sanded a few things??has anyone else done this?
Old May 25, 2008 | 08:38 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Ok to paint Engine?
yeah get some engine enamel and go to work. A wire brush helps alot along with some sanding.
Old May 25, 2008 | 08:43 PM
Jix01's Avatar
Engine: 305 5.0 TBI
Old May 25, 2008 | 10:12 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Masking tip: Aluminum foil is your friend in this situation.
Make sure you CLEAN all the GREASE off the areas you are painting, too. Any degreaser should work fine. Just be sure to read the bottle/can and make sure it won't hurt your aluminum. I would suggest cleaning before and after sanding.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
