primer!
Old Jun 6, 2008 | 09:49 PM
garrick's Avatar
primer!
okay so i'm not the best body guy and i have a few dents to take out of my bird, i'm going to end up paint the car jet black, should I use an epoxy primer or a high build primer? i'm priming over some paint some metal.
Old Jun 6, 2008 | 10:02 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: primer!
I used highbuild on mine, since I used a lower grit than I shoudl have. If you have scratches, then use high build to cover some (the smallest)
Old Jun 6, 2008 | 10:32 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: primer!
since you have few dents, just use high build primer on body work area. Make sure you finish with 400 grit or higher, otherwise you will see scratches through the paint..by the way I painted my truck jet black in April and it came out really good.
good choice on the color
Old Jun 8, 2008 | 01:10 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: primer!
the only time you need to use a epxoy/etching primer is when you are priming over bare metal. if their is paint or factory primer still attached then just use some high build.
Old Jun 8, 2008 | 07:35 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: primer!
exactly
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
1984Firebird502
Nov 20, 2001 12:46 AM
89Iroc-ZL98
Sep 27, 2001 11:11 AM
Mikes86SC
Jul 16, 2001 09:31 AM
