Painting Iroc rims
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Painting Iroc rims
So I picked up a set of iroc rims really cheap, 250 for the set.
Heres what they looked like as I bought them
So I had to paint them, only have the fronts finished so far.
So what do you all think? Good for my first time really painting anything, even though I used rattle can paint?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Painting Iroc rims
Wow those look great! what article did you follow on polishing them or did you do it your own way? i like how the factory machining marks are still slightly visible.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I Think that it looks really good. Looks like you made all the corners crisp and I see no overspray. Good Job!
for polishing I used some fine grit sand paper, and uses American Racing Metal Polish (the cloth stuff). I spent most my time just taping the polishe parts off, cut the tape with an exacto knife to get good lines, and just use a fine grit sandpaper to get any overspray off. Polishing could be much better, theres minor defects in the aluminum that I just couldnt get to go away, and I didnt dare try anything more abrasive than what I already used.
Car: 89 IROC-Z
was there any clear coat on them and what grit did you use?i never heard of that cloth metal polish. looks like it did a good job nonetheless!
The previous owner stripped the clearcoat, I used mainly 1000 and 2000 grit sand paper, and some synthetic steel wool stuff that was pretty fine. I got almost all the stuff from eastwood. Some I had laying around.
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Look awesome. I painted those same IROC rims (the one line ones) and it also took me rediculously long to tape off the polished parts. Well worth it though!
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I started polishing mine, but I started at 50 grit, and moved up to 1500.. Took like 8 hours a wheel.. I eventually got bored and only did the fronts...
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
You did an excellent job
Especially since this was your first try. Prep work is time consuming, but well worth the efforts. Thanks for the pics.
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
looks really good. I might want to take some 2k sand paper to my Wheels.. Also where did you get the American Racing Metal Polish
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Those look really nice. I'm going to get some IROC rims like yours and paint them the same way.
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Goddddamnnn.... They look excellent! Sometimes I wish I finished those wheels before I sold them to you.
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
mustangman65_79
Aug 11, 2015 03:17 PM
fl, grit, houston, iroc, minnesota, owner, paint, polish, repainting, rerpaionting, rims, sale, sandpaper, tallahassee, wheels
