Lets see your valve covers!
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Shopping around for a new set of centerbolt valve covers, not sure which ones to go with. Lets see some pics!
Re: Lets see your valve covers!
I have these on the 77 corvette, probably going to put them on the IROC also.
DeBoTech makes those. It's a nascar filter for 16" aircleaner elements. They are usually painted white on the outside but I liked the bare carbon better, even if it shows the marks from vacuum bagging (the perfect carbon is on the inside)
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I also have these, same as the ball milled ones above, just not ball milled.
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
GM Peformance Parts Chevy Competition Valve Covers
I love them GM Peformance Parts Chevy Competition Valve Covers, however they are not centerbolt covers. What needs to be done to change them over? Centerbolt covers are ugly in my opinion, do you need to swap heads to have ones without centerbolt? TPI setup covers them up anyways though, i dont even know why i would consider.
You need a set of adapter plates. They are not cheap though.
Car: '91 Camaro Z28
I have 2 sets, they never leaked. One thing I do is use studs on the perimeter holes, that way you will not distort the pltes when you bolt down the valve covers. Also some permatex sealer works miracles.
Car: '91 Camaro Z28
I'll have to try the RTV. The studs I'm using on the perimeter don't hold onto the adapters very well, so when tigtening down the nuts, its almost spinning the studs in their holes.
I'm not using RTV, I'm using aircraft form a gasket, it's a thick black/brownish smelly goop that you brush one. It looks like condensated oil and comes in a white bottle witha twist cap with brush.
I have those too and they are porous, they started oozing oil so I stripped them bare and coated the inside with glyptal.
Hey Twin Turbo,
No problems with clearance? AC and all? I put those on the '68 but since the bay is a little more open, i had no problem. I wanted to put em on the Formula but i didnt think i had enough room.
They're installed on my 83 truck it has plenty of room for them, it doesnt have AC but a home made AC eliminator heater box. I don't know if they would fit with AC on an f body.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Proforms, just like the ball milled posted earlier, without the ball milling....
....add silver metallic powdercoat....
...add gunmetal metallic vinyl graphics...
...add GM badge....
I think in the future though, i'm gonna go with these VC's, but with black crinkle.
...add GM badge....
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Work in progress. It's dirty, and all the aluminum is smudged and finger printed. Once I get everything buttoned up, I will clean it all up.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I always dug the polished aluminum look even when it oxidizes... Mine are in dire need of a good polish job at this point... but I still think it looks way better than chrome.
I kinda wish they were the ones that said "CAMARO" across them, though, but whatever.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>My engine bay.....for now.
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Heres my cheap AZ valve covers, before I cleaned up my engine bay and made it look better.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
