KLEARZ taillights
Old Dec 9, 2008 | 07:25 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
KLEARZ taillights
i recently completed the taillights for my camaro. i went with all clear lenses and used led bulbs. this thread is about how i received, assembled, installed, and completed the taillights. i know im not the only one to purchase the taillights so i encourage those to post on the direction they went. i am not an expert in fabrication but i know my way around shop tools. this is my expierence and want to share it with everyone interested. there is good and bad.
overall i am satisfied with the taillights. to quote what someone here had previously said, " if you take your time and follow the directions" they will turn out great.
it took about a week to assemble the lights. i had an extra set of taillights that i previously prepared for the new lenses. after removing the old lenses, i removed all the caulking from the housings. i cleaned and painted the housings, using gloss black for the outside and chrome bumper spray paint for the inside. i even took apart the license plate lenses and cleaned and painted them.
Old Dec 9, 2008 | 07:31 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Re: KLEARZ taillights
after laying everything out and making sure i had everything , i assembled the lenses. as in the directions, sand file and heat as needed. REMEBER TO CLEAN THE HOUSINGS AND INSIDE LENSES PRIOR TO INSTALL. nothing like permanent prints to ruin the whole thing. after double checking fitment, i caulked the lenses and assembled the first three on each side. i used painters tape and a few assembly clamps to secure the lenses to the housing. put them up to dry and go at it the following day.
put on the corner piece and clamp and tape it. let that sit over night. wipe off the excess sealant as you go. after it dries remove the excess by rubbing it off. RESEAL THE AREAS YOU MISSED OR NEEDED. i did this a few times to both assemblies. check your work and TAKE YOUR TIME.
Old Dec 9, 2008 | 07:40 AM
tonys91rs's Avatar
Car: 91 Camaro RS
i cleaned them up and used 1/4 inch black pinstripe in the grid pattern. why? because its easier than to paint and i can remove it or change colors. i thought it looked good.
the rear bulbs were replaced with led lights. the brake and signal bulbs are 24 led bulbs. the back up bulbs are 12 led bulbs. single led bulbs were used in the corner and plate lights. the bulbs were purchased on ebay.
Old Dec 9, 2008 | 07:48 AM
tonys91rs's Avatar
Car: 91 Camaro RS
another pic:
Old Dec 9, 2008 | 07:59 AM
tonys91rs's Avatar
Car: 91 Camaro RS
ok now the good and bad. the lenses after completetion are not factory perfect. however i think mine turned out great and they look good. i could have done better or worse. never the less it was fun and im satisfied. dont take this on unless you are confident with your self. if your looking for a "snap tite" skill level project, this is not it.
im having a problem with the signal led bulbs. they are not flashing and were difficult to plug in. ill fix that later this week.
im going to fix my third brake light and i recommend if you are going smoked or clear, you make sure it works. the red brake lights are faint in direct sunlight. at night they look twice as better. ill post a pic of them at night later this week.
check your local and state laws. in georgia, all vehicles are required to have a red reflective lense at the rear of the vehicle. that does not mean it must be the taillights. im working on that problem now. i have some ideas. my camaro is a weekend toy, not a daily driver.
ive been in contact with klearz by email. they were informative and quick to respond. post any questions or comments. ill help as best as i can.
Old Dec 9, 2008 | 08:01 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
wow, first time seeing these. very unique! A+ on the effort and very nice visual modification.
...You have a 305TBI to go with those SS emblems?
haha just messing with ya a bit. very clean RS!
Old Dec 9, 2008 | 08:17 AM
Demon355's Avatar
Looks real nice! I want to see a set of the smoked all red tails...
Old Dec 9, 2008 | 08:19 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
i've looked at the website many times, but never found the contact information. Do you know their phone number by chance? Thanks
Old Dec 9, 2008 | 08:24 AM
ChevyRockstar's Avatar
Car: 1984 Camaro
Engine: 2.8
very nice but i have had leds in the reverse light before, they dont light up as much area as a regular bulb. I honestly didn't think i would like it but i reallly dig it! Great Job
Old Dec 9, 2008 | 03:05 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
who .. whatha... ??? whoa whoa .. how come I seem to be the only one who hasn't heard of these "klearz ? Where TF do I get some of these lights ???
That is freakin crazy.
Old Dec 9, 2008 | 03:11 PM
Car: 1987 IROC Z
Also, did you fab the LED setup and do you have any pictures of it ? Post all pictures of the process youy have available and i will post them as a separate gallery on http://badassiroc.com
Old Dec 9, 2008 | 05:09 PM
tonys91rs's Avatar
Car: 91 Camaro RS
ill try to get some more assembly pictures up, but im having a problem recovering them from the camera.
i didnt fab the led set up. i know someone else here is in that process. i just ordered some led bulbs from ebay, VLEDS i think is the company name. they were simple plug in like regular bulbs. the problem i had with the signal bulbs is that they barely fit in the socket so i had to trim the slots a little inside the socket. now they work with the flashers all on but dont flash when the left or right signal is activated. they just stay on. ill fix it i replace them with regular yellow signal bulbs.
Old Dec 9, 2008 | 05:16 PM
tonys91rs's Avatar
Car: 91 Camaro RS
do a search of the forums for the link to the web site. you will find the original post in "group purchases".
Old Dec 9, 2008 | 05:26 PM
tonys91rs's Avatar
Car: 91 Camaro RS
this is a night pic. these are just the taillights, and not the brake lights. the brakes were not applied. pretty bright.
Old Dec 9, 2008 | 05:31 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
nice job, to have leds flash with your bliker you need to wire up sort of resistor inline with the blinker....read up on it and a lot better site for leds is superbrightleds.com...enjoy...
Old Dec 9, 2008 | 06:18 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
heres the link.
https://www.thirdgen.org/forums/grou...ww-klearz.html
Tony they look great. I hope mine turn out as good. Good call on the pinstripe. Ive been scratchin my noggin thinkin about how im gonna get the lines back in. SOOOOOO, im gonna steal the idea.
Old Dec 9, 2008 | 11:56 PM
Kandied91z's Avatar
nice to see pictures on the car. visually they don't look to bad in pictures. i really had my heart set on these after trying to privately contract a company to make a set i gave up with the expenses so it's nice to see some sort of option. i share your opinion on the fit and that's exactly why i have steered away as with that many single pieces it will be impossible to match the oem finish but what can you expect as for the price you can't beat it.
looks nice!
Old Dec 12, 2008 | 08:53 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Thanks JERK! Just creamed my pants at work. Not work safe, this should have been labeled.
Haha, just playing, just they look so DAMN ****ING EXTREMELY GOOD. I bought my dark smoked and cant wait....
AHHHHHHHHHH THESE LOOK GREAT!!!!!!!!!!!
K91Z, we were able to get full with housings replacements for our cars but nobody wanted to fork up $75 for the down payment of making new housings as well....which would have made them a full replacement and not in pieces...but it is what it is.
But like you said for what they are in price, they are no where near bad.
Later guys, going to clean my pants now.
P.S. LED bulbs, Mm Mm Good!
EDIT: Re-read your good and bad post, maybe you should look into this guy, i bought my LED bulbs for my nissan 300zx from him, and plan to do the same for my camaro. they are 13 watt bulbs, the brightest LED's I have seen and are easily noticeable during the day.
Look here, they are $20 a set but well worth it...cant wait to get my tails and do this ****...haha. Later.
Check here ( Warden JP2002 ), search the results for " 13W " without quotes, and it'll bring up his brightest ones, be sure to check size, also he sells relays you use to keep your blinkers working properly, just replace your stock relay and boom bang, good to go. Where is the realy, im not sure..haha sorry. But there ya go.
Old Dec 15, 2008 | 07:15 AM
tonys91rs's Avatar
Car: 91 Camaro RS
a few more pics that ive taken:
after a washing and some rain, i found no leaks or water problems. im going to get the relay for the signal leds. these pictures do not show very much detail, but up close i dont see any alignment problems or waves in the lenses. ive already received a lot of comments both good and bad. i respect everyones honesty.
i went with the clear lenses because they are much easier to change the color later on if i wish. if you get a set i do recommend that you engrave an identifcation number somewhere on them.
Old Dec 15, 2008 | 07:24 AM
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
they look alot better than i thought , nice good work
Old Dec 15, 2008 | 11:25 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
awesome man i love it. I remember prolly about 8 years ago i was going through town and seen a third gen camaro in a drive way that had clear lenses and they looked really bad.... but yours look great and the led bulbs are awesome. love it man -Matt
Old Jan 22, 2009 | 03:04 AM
Team Step It Up's Avatar
I Am Definatelly Going To Try To Get ahold Of This Jason Guy From Klearz So I Can Buy A Set Of The Smoked Black Ones,Think They Would Look Good On My Car?,The Contact Email I Have Is Info@klearz.com , I Have A 1991 Z-28 With A ZZ4 Crate Motor [383 Basically](No Its Not Running Yet.......My Dad And Brother Are Helping Me Build It,Im Only 19),Please Dont Flame Or Insult Me,I Know Im New To The Camaro Scene,But Im Trying To Learn - MJEW@teamstepitup.com
Old Jan 22, 2009 | 03:13 AM
Also How Did You Pay Him Tony?I Have A Little Over $1,600 In My Paypal Account But I Dont Have A Credit Card/Bank Card,Does He Take Paypal?Or Do I Have To Send Him A Check Now?
Old Jan 22, 2009 | 06:03 AM
tonys91rs's Avatar
Car: 91 Camaro RS
i paid mine through paypal.
Old Jan 22, 2009 | 10:14 AM
Just Sent In My Order Info,Waiting For A Reply,Ill Be Paying and Waiting For Them To Ship Out,Putting Them Together And Posting Pics When The Paint/Bodywork Is Done,Anyone Know How To Make A ZZ4 CA Smog Legal?(Just Till I Can Get The Slip Saying It Passed.........Then Ill Unleash The Beast LOL)
Old Jan 22, 2009 | 11:05 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
I don't like it.
Old Jan 22, 2009 | 09:04 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Looks better than I thought it would.
It might look sweet to do body color stripes between lenses.....
Old Jan 30, 2009 | 11:21 PM
89RS.SS's Avatar
Car: 89 Camaro RS/SS
Engine: 5.7L 350 carburated
They look okay but not my thing. If i wanted clear lights ida bought a honda. no offense guys. sorry peeps not bashing the lights or your style. it does look alot better than i thought it would. well thats my 2 cents n im out for the night. peace.
--mike--
Old Jan 30, 2009 | 11:37 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
funny..the 5-0 is already at the end of your drive ready to write a ticket...lol...I believe those kind of lights are illegal in MI...but i'm not 100% on that
Old Jan 31, 2009 | 01:28 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
im working on minr today, trying to buff out a scratch. I had a little vinyl left over from my headlights, so i smoked the plate lights.
a big thanks to tony... the pinstriping idea was perfect.
one with flash. one without
Attached Thumbnails KLEARZ taillights-tails-001b.jpg   KLEARZ taillights-tails-003b.jpg
Old Jan 31, 2009 | 01:40 PM
19CAMARO85's Avatar
hey loneroad i like the look of them. Post pics on the car asap.
Old Jan 31, 2009 | 02:58 PM
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
can you put a new one and a old one next to each other so we can see the difference just want to get a idea how much darker they are. looks great
Old Jan 31, 2009 | 05:47 PM
Demon355's Avatar
Oh I love those loneroad! I wanna see those on the car!
Old Feb 19, 2009 | 11:41 AM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
here is some pics . dont mind the paint
Attached Thumbnails KLEARZ taillights-tails-002.jpg   KLEARZ taillights-tails-004.jpg
Old Feb 19, 2009 | 02:02 PM
Demon355's Avatar
Those look friggin' awesome! I want a set! Maybe get a pic of the whole car showing the back section?
Old Feb 19, 2009 | 02:17 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Loneroad, looking great. Did you use 1/4" tape as well because your lines look a little thicker than tonys setup.
I will be having my lenses lines painted in, and on the inside, to keep the smooth look on the outside, but thats still undecided but they will be painted, flat black too.
But definitely more pictures, with and without lights.
Have mine, waiting until Summer to have someone install them. Si I can blame them if something happens...haha.
Old Feb 19, 2009 | 04:11 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
so you put that vinyl tint stuff on your headlights?
I was thinking of doing the same thing could you put a pic?
Old Feb 19, 2009 | 04:30 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome work with the leads and new clear taillight hosuing.
I hope they make it for the trans am when the economy gets back up
Old Feb 19, 2009 | 06:23 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
I got the vinyl from rvinyl.com Ill try and get some headlight pics up for ya. gimme a couple of days.
Old Feb 19, 2009 | 07:23 PM
liquidice's Avatar
Car: 84 Z28 L69
Engine: 305 H.O
Axle/Gears: factory 10 bolt 3:73 posi
can i still get these tail lights in smoked? and how much will they cost now? still $200?
Old Feb 19, 2009 | 07:24 PM
KITT1983's Avatar
loneroad I also see you got an electric flip plate nice. most likely from flipplate.com.
Old Feb 19, 2009 | 09:44 PM
  #42
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
Lol i thought you were BSing me. I never knew there was such a thing. That is awesome.Mine is stock, the trunk lock is behind there. I do pay a crap load of tolls tho..hmmmmmmm something to think about
Old Feb 19, 2009 | 11:46 PM
  #43
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Send them an email!!!!
Info@klearz.com
Old Feb 20, 2009 | 05:13 AM
  #44
KITT1983's Avatar
It is amazing how many knight rider inspired products that are available for cars today. There are so many manufacturers of electric and manual flip plates.
I have a manual one on my KITT The Altec 400:
http://www.youtube.com/watch?v=hqUSWCdVIoY
Old Feb 20, 2009 | 06:08 AM
  #45
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i think they look awesome nice job btw what back up bolbs do you have i like them alot.
Old Feb 20, 2009 | 08:47 AM
  #46
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Price will be $250 for non down payment members.
http://klearz.com/camaro.html
Old Apr 15, 2009 | 05:44 PM
  #47
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
got mine today. very poor quality and thats all i am saying
Old Apr 15, 2009 | 05:59 PM
  #48
Car: 1991 Trans Am
Axle/Gears: Stock
what kind did u get?
Old Apr 15, 2009 | 06:05 PM
  #49
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
smoked red with smoked klear reverse the smoked klear is very dull, the lenses are very scratched up and the fit is very crooked
Old Apr 15, 2009 | 06:12 PM
  #50
Car: 1991 Trans Am
Axle/Gears: Stock
ah that sucks well now you know i guess.
