Cell phone antenne.....
Old Jan 25, 2009 | 10:12 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
well someone thought it would be a good idea to put a hands free phone in my car before I got it, and now I got this nasty *** antenna base on the rear glass. What I want to know is, do those stupid *** antennas go through holes in the glass? Or is a miracle and I can just go in and take it off. Because the problem is that my car is a factory notchback, and I don't think I would even be able to get a new piece of glass to go back there. any ideas?
Old Jan 26, 2009 | 12:51 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Cell phone antenne.....
They don't go through the glass, they work on a capacitive principle and send the signal from one plate to the other through the glass. It's a VERY strong adhesive they use though to stick them on (inside and out). You might want to be really careful on the inside so you don't damage the defroster lines.
Old Jan 27, 2009 | 08:55 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
thanks man, I really want that thing gone. Im going to try to take it off this weekend...
Old Jan 27, 2009 | 09:50 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Go to walgreens and find a product called ''goo begone''. its the best adhesive remover I have ever used.
Old Jan 27, 2009 | 09:57 PM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
straight up ammonia should eat it away too. it works well on things like that. just wear a mask because that stuff is strong. and as someone else stated, don't scratch the defrogger lines
Old Jan 28, 2009 | 01:13 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
You can also use a piece of fishing line to cut the box off then use the goo gone to remove the adhesive.
Old Jan 28, 2009 | 08:36 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
thanks a lot guys, I'm goingg to try some of the things you guys said. thanks!
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
3.8TransAM
Sep 27, 2015 08:37 PM
ULTM8Z
Sep 16, 2015 09:15 AM
