rust spots emerging from my hood
Old Jul 31, 2001 | 05:56 PM
Ragin'87's Avatar
anyone got any tips to stop this? as of now, the spots are small..
but they're scattering.
thanks.
Anthony
Old Jul 31, 2001 | 06:12 PM
mtx28's Avatar
either sand blast it or have it blasted. you can get a blaster for less than 100$, but you need a compresser too. if you do it(or omeone else) tell them to spray an anti-rust material on it, then paint. the hood is easy to do also, if you are going to do it, talk to me for some tips(just got done doing my 74
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Jul 31, 2001 | 06:25 PM
camaro chick's Avatar
Small little chips can be covered up with scratch color-you basically want to seal out oxygen. This will not stop the rusting, but it will keep the rusting in a smaller area and won't spread too far. Problem is-the rust will want to eat a hole from top of hood to bottom side. It's a temporary fix that will but you some time before you do the body work properly for a new paint job. If you just want to go ahead and get it over with, you will have to do a lot of sanding or use grinding discs (probably your best option). I don't know how familiar you are with body work, so I'll just give you a quick rust preventing overview. Get the rust you can see off-you'll see little black dots in the shiny metal where you have just removed the rust-take care of the dark spots or it will just rust up again. Don't grind away into the newly uncovered metal though, just take it easy on it, your common sense will tell you when enogh is enough. Go over the spot with some laquer thinner, mix up some RAGE (always had good luck fixing little spots on cars with this stuff)lay it over the spot and wet sand until smooth. Spray over with rustoleum then spray paint your car color over it. If done right (no missed areas) the rust will never return.
Old Aug 1, 2001 | 09:04 AM
Ragin'87's Avatar
I had a HUGE rust spot in the center of my hood in the 87... and I took that out with the good old grinding disks, but that was just one localized spot. I currently have about 5 or 6 really small(smaller than a pencil eraser) spots, that only I notice. But you guys know how that is, **** on your car, that you bitch about, but no one else can even find. It was a real bitch to get the repainted area on my hood to look good on the 87, and I really don't want my car to look like ****. It's black, so I don't know if that makes it easier or harder(the 87 was gunmetal metallic.)
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Aug 1, 2001 | 05:27 PM
Black isn't so bad to work with. I had a $400 black camaro with about a hundred of those little spots on the hood. I went over them with the scratch color once, then a second coat. To make everything look nice and even, I used black polish and buffed the hell out of the car twice over using an aircraft buffer, and once over by hand. Scanner not working now, but if it was I could post the pics... car looked mint.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
