Polishing IROC wheels
Old Apr 22, 2009 | 01:36 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
hey ive read all of the threads on refinishibng the iroc wheels but i was wondering.... I have been sanding by hand till my hands fall off but they still look like monkey feces..... anyone know if I can use ....say a palm sander or perhaps a grinder with the proper abrasive pads to make it go quicker?..... dont really like the idea of the dremel b/c of the small surface it can work at a time.... just seems like i would get a more uniform finish with a sander or grinder.... has anyone used one of these on the wheels... and maybe a cpl pics of the results..... THANX!!!
Old Apr 22, 2009 | 08:51 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
Re: Polishing IROC wheels
I don't know what your reading, but if your hands are falling off,..it sounds like you're sanding more than you need to. Purpose of sanding is really to bring out a layer of fresh aluminum. It should look very bright but not reflective. 400 grit is the highest I went. Dry first and then wet. Going with a higher grit paper will make the scratches go awayand make it glass smooth, but will continually dull the luster. Use compounds after the 400 of decreasing grit and finer polishing buffs until you can shave in the wheels.
Incredibly long process it is, but well worth it. Good luck, and thanks for the laugh with the monkey feces comment
Old Apr 29, 2009 | 04:57 PM
87SnowFlake's Avatar
Car: 87 IROC-Z
Engine: jasper 350
Transmission: 700R-4
Axle/Gears: 2.73 posi
Dmans85. do you have any pictures of your wheels? (if you did them)
Old Apr 29, 2009 | 10:24 PM
ajk511's Avatar
Car: 1991 z28
https://www.thirdgen.org/forums/auto...oc-wheels.html
Old Apr 30, 2009 | 11:14 AM
1Aauto's Avatar
Former Sponsor
Here's a cool article I found.i might try this on my Cherokee wheels.
http://www.flashoffroad.com/features...on_wheels.html
Old Apr 30, 2009 | 11:18 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I polished my '86 wheels and they look like mirrors now.....what I did....started with 400 grit, then 800 grit, then 1500 grit.....sanded till my hands fell off too (8 hours per wheel), I sanded till all the machined ribs were gone, then I took a high speed polishing wheel, some mothers aluminum polished, and shined them out (spent about 1 hour per wheel buffing)....they look GREAT!!
Old Apr 30, 2009 | 12:36 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
http://www.eastwoodco.com/shopping/p...iProductID=953
This works great and you can use a drill just watch the chuck don't let it hit the wheel. Or you can buy a buffing motor/grinder.
BlueIroc-Z
Jun 9, 2019 03:22 AM
kah992
Aug 19, 2015 02:55 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
