Easy fix for fading t tops!
Old Aug 6, 2001 | 12:20 PM
bustatc's Avatar
Hey everyone, I just wanted to tell you about a simple and easy fix for the outer plastic on the t tops, I know that a lot of people are having the problem that they are fading and it looks like crap. Well I was afraid to paint them myself at first because I was afraid that it would look bad since I have never painted anything before. But all you have to do is first remove the t tops and put them on a table or something to make sure that you don't get any overspray on your car, then you mask off the glass and little rubber weatherstripping and you get some 400 grit wet sandpaper and a can of black trim pain (you can get it at any walmart or autozone) and get some rubbing alcohol to make sure that the surface if clean. Then you take the sandpaper and dip it in a little water and just sand ever so slightly just enough to make the pain stick, don't do it too much or you could leave scratches. Then apply a generous amount of alcohol to a rag and wipe over the t top plastic good. Then let dry about five minutes and then shake up the can real good and in a sweeping motion put a couple thin layers of paint on and then let sit about 5 to 10 minutes and then do the process again and then let sit another 5 or 10 minutes and then do it again. By this time your t tops should look new but if the fading is really bad you might need to put another couple coats on, just make sure that you don't put too much paint on at a time because it could run. After a couple hours they will be dry, but I recommend letting them sit over night and your t tops will look like new. I hope this helps someone. Good Luck!
1988 Carmaro RS
Bustit.Org
To see pictures of my Camaro, go to Bustit.Org and click on the About me page!
GTS Black outs for front
GTS Black outs for back
LeBra bra
K & N air filter
Flowmaster 80 series with Edelbrock Chrome tips
Old Aug 6, 2001 | 01:29 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
huh, i just did the same thing to mine about 2 days ago....
great minds think alike i guess...
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Aug 6, 2001 | 01:35 PM
Jiffy's Avatar
I found out that teh Rain-x window protector liquid stuff, really makes them shine black. It stayes longer than alcohol. Just my .02
Jeff
92 Camaro V6, mods: K&N, modified air box, JET chip 2,high performance muffler.
www.camarors.4t.com
Old Aug 6, 2001 | 07:33 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Does anybody think it would look okay to paint these strips the color of the car? Perhaps white? Or would black look better?
customblackbird
Aug 15, 2021 10:16 PM
evan555222
Sep 20, 2016 02:51 AM
Dkelz313
Apr 7, 2016 10:38 PM
Catcher55
Aug 15, 2015 07:08 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
