How do i take the belt moldings off my 88 trans am and where do i get new brackets
Old May 14, 2009 | 06:55 PM
chrismann888's Avatar
Car: 1988 t/a white
Engine: crate 355
Transmission: rebuilt orginal
I'm almost done taking my car apart and getting it ready for its brand new paint job. The only thing is i want to replace the belt moldings on my doors how do i do it do i need to drop the glass windows. If anybody knows let me know also i need new metal brackets for my ground effects. If anyone knows where to get those i would appreciate it very much Thank You
Old May 14, 2009 | 07:27 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: How do i take the belt moldings off my 88 trans am and where do i get new bracket
i dont think you can buy new brackets, ive never seen them. junkyard is probably your best bet. on another note, not to be a **** but does your info thing say you have a crate 350 "boarded over 30"?
Old May 15, 2009 | 09:20 AM
Steve86TA's Avatar
Car: To many to list
If your talking about the moulding on the door and smaller pieces on the fender and rear 1/4 panal..thoses are held on with double sided tape..Which brackets do you need?I may have a few around.LMK
Old May 15, 2009 | 11:12 AM
Car: 1988 t/a white
Engine: crate 355
i need one for my passenger ground effect that would be great if you have some!
Old May 15, 2009 | 11:17 AM
Car: 1988 t/a white
Engine: crate 355
i mean the right passenger door ground effect
Old May 15, 2009 | 09:26 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
The door ground effects don't use brackets. They are fiberglass and have studs screwed into them.
Old May 15, 2009 | 09:33 PM
Car: 1988 t/a white
Engine: crate 355
Every part of the ground effects has a metal bracket that's the flaw with this model because when you take the ground effects off they could be deteriorated. The studs are screwed into the bracket and the ground effect to keep it together better
Old May 15, 2009 | 09:44 PM
Former Sponsor
Car: Too many
The 85-90 style Trans Am door ground effect pieces don't use any type of mounting bracket at all. The studs screw directly into the fiberglass. If you've got a metal bracket behind them you don't have the original ground effects on the car.
Only 91-92 Camaros and Firebirds used metal brackets on the door ground effect pieces.
Old May 18, 2009 | 02:12 PM
Brennan's Avatar
i think he might mean the rocker ground effect which do have a bracket behind the door, mine do anyway.
Old Dec 7, 2009 | 10:26 AM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
hes righttt..... my 87 iroc has studs and my 92 rs has brackets
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
jahblah
Aug 12, 2015 05:54 PM
sonu1975
Aug 11, 2015 08:38 AM
