Tinting my windows
Old Aug 11, 2001 | 10:13 PM
89Firebird Formula350's Avatar
Tinting my windows
Have anybody tinted their windows themselves? I was thinking about doing it myself, but it seems like a pain. What do you think, is it easy?
Old Aug 11, 2001 | 10:55 PM
White_Boii's Avatar
iv never tried it but...
https://www.thirdgen.org/newdesign/tech2/tinting.shtml
im sure that can help ya out. at least its a start.
Old Aug 11, 2001 | 11:03 PM
Thanks white boii! I appreciate it!
Old Aug 12, 2001 | 03:05 PM
White_Boii's Avatar
anytime....maybe you can get some people that have done it to reply to this, maybe they have some more tips...its definately cheeper, and it takes lots of patiants...especially your first time, may have to redo a lot...but take your time, bubbles and mis-alignment sucks!! and be sure to get some good tint that doesnt turn purple too!
Old Aug 12, 2001 | 04:57 PM
Jza's Avatar
Jza
I suggest doing it in a garage if possible. If you can't then at least wait for a day with little or no wind. That'll help keep out little bits of dust, grass, or bugs, and keep the film from trying to blow away and getting wrinkled (one crease and it's there for life!).
Old Aug 13, 2001 | 01:07 PM
Going Slow Sucks's Avatar
when I worked for a dealership they showed me how to do it. And it looks a lot easer then it realy is, and those film sheats are not cheep.But here's the tip's i know of.
One.when sizeing your film spray a soap/water mix,and use a plastic/rubber scraper to get rid of any air pockets. do this on the out side it will make it easer)
Two. clean the glass with soap and water Never ues windex.If you smoke use a razzor blade on the inside to scrape them clean
three. spray the inside of the glass with the soap/water mix.then place the film on it. use a heat gun to make the film flex a small amount but don't heat it to much. with a small plactic/rubber scraper push and pull the s/w mix out.
four. this is the most important . don't try to do the back window if you don't think you can.The back window need's to be done in two sheats of film because of the curve of the glass.
sorry about the spelling, if you have any Q's my E address is somewhere in here
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Aug 13, 2001 | 01:41 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Probably more troble than it's worth. Most tint shops will do your whole car for $125.00 with a warrenty. If you screw that back windiw up (if you have defrost) you will really have fun getting the tint off and not destroying the defroster. Somethings are best left to the pros. Sorry to sound like doom and gloom.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Old Aug 13, 2001 | 07:18 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I agree, go with the pros, They did one single sheet on my back window, and it looks good. My whole car only cost 100.00 bucks, with lifetime warrenty.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
