Need some help: 'Painting' Cam's eye buckets
Old Aug 8, 2009 | 10:24 PM
KatsCam's Avatar
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
Hey all, I need some help here. I recently put black rally stripes on Cam. I wanted to then paint her eye buckets black to match.
Well, while contemplating that, and trying to decide flat or gloss black, I mentioned it to a friend, who then got the light bulb over his head and suggested I do them in the same vinyl as the stripes, since I have left over.
Great idea, but I am now having trouble getting a precise drawing to cut the vinyl with. I don't know anything about CAD. I tried to use aluminum foil, which is flexible, but too brittle. Lightweight butcher paper, which is good, but not flexible enough.
What I am trying to do is get the shape precise enough to not have to cut the vinyl on the car after applying. (Makes me nervous!) Am I dreaming about this being possible?
Thanks for any ideas you can come up with!
Old Aug 8, 2009 | 10:30 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Need some help: 'Painting' Cam's eye buckets
I don't have much knowledge about this stuff, but it seems possible to me. Try cardboard or something, like a box you have sitting around. It's worth a try!
Old Aug 9, 2009 | 08:26 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Tape 11 x 14 paper (or bigger if needed)rolled out from between the headlights left and right going up the sides of the bucket to the bucket. Tape as if you want to cover the entire bucket plus another inch out. Extend the paper past the buckets. Take a marker and trace the buckets on the paper. Take paper intact of and lay flat. You now can clean up your lines and have a templet for your vinyl.
Old Aug 10, 2009 | 06:18 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Easier to just cut out on the car. Ive dont alot of cars in the past. just use a soft hand and NEW blade.
If your worried about cutting thru and into the paint. just use a very light hand with just a blade. You should be fine. vinyl is thick.
Personally Id just sand the clear coat down with 800 grit and paint them.
Street Lethal
Apr 30, 2019 12:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
