Interior Restoration Teaser Pics
Old Oct 11, 2009 | 01:29 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Just thought I would show everyone a few snapshots from my current project: Interior restoration.
Center console about 75% finished with fresh paint and carpet, custom restored handle/lock panels, and arm rests. The one on the top is the original (passengers side) one, but the one on the bottom is It's driver side twin with fresh VHT vinyl dye.
For the console, I hit the entire thing with Krylon fusion satin black. I did the lower console too, about a week before I decided to carpet it LOL! For the upper console, I'm putting in fresh hatch/window switches with visible graphics and metallic red trim. The blank area below the switches where the rare console clock can be found, I cut out an 80mm hole. I'm going to install a high CFM red LED fan here with a chrome grill for some blingage, but it will be functional. It's function will be for one of two things:
Currently, I'm looking into the option of refrigerating the console glovebox. If I don't take that route, the fan will provide fresh airflow inside of the console for the head unit. The ashtray (not pictured) had been sprayed with VHT gloss rollbar paint and has a hidden killswitch installed in the form of a high security radial lock. As for the glovebox lid, no matter what approach you take the stupid vinyl ALWAYS wears out and cracks. So I ripped that crap off and carpeted the lid.
As far as the handle trim panels, I also sprayed those with krylon fusion, painted the fake (as well as the real) torx screws with red brake caliper paint (I know it will never hit 900F but the color matched well), and installed new lock switches with fresh graphics and painted over them with Clear acrylic paint to preserve the switch graphics. I took this same approach with the window/trunk hatch switches.
I'm getting ready to put the doors back together in a few weeks. Things I've done so far:
- Replaced both window motors
- greased lock actuators and replaced failed rivets on drivers lock actuator which caused the door to not lock unless manually operated.
- Adjusted window guides
- Removed door handles and sprayed them with satin black VHT rollbar paint. (Can you imagine the look on my passengers face when I told them to, "Slide that rod forward", to open the door )
Things left to do to doors:
- Remove regulator tracks and clean/lubricate since passenger window is STILL creeping.
- Adjust window stops
- Replace outer drivers window sweep
- Use POR-15 Silver in the bottoms of both doors. The passengers door just has a few dime sized rust areas, but the bottom of the drivers door is rotted to hell due to offending window sweep allowing water inside the door. These materials are on the way and should be finished in a little over a week (work sucks sometimes).
- Put doors back together!
More progress to come. Hope you all enjoy!
Attached Thumbnails Interior Restoration Teaser Pics-img00336-20091011-0128.jpg   Interior Restoration Teaser Pics-img00311-20091001-1604.jpg   Interior Restoration Teaser Pics-img00292-20090924-0318.jpg
Old Oct 11, 2009 | 01:33 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: Interior Restoration Teaser Pics
looks great so far not sure if I'm a fan of the red torx screws though
Old Oct 11, 2009 | 01:51 AM
Car: 1985 Z28
You know to be honest, I thought the same thing. After I first painted them I thought, "Oh crap what did I do now I have to STRIP the panels and start over to get rid of this tonka truck red". The more you stare at it though, the more it grows on you and begins to look mean against the black. I think the key is keeping it subtle. Small red accents here and there.
Old Oct 11, 2009 | 08:53 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Looks good so far....
Old Oct 11, 2009 | 08:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
subtle would be keeping the screws black.
red is yuck!
Old Oct 11, 2009 | 02:14 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I have to agree on the red painted torx screws--they just look cheesy. I think the way to fix it might be if you could locate some red aluminum ones...Personally I would just leave them black and move on.
Old Oct 11, 2009 | 02:32 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Is that a cupholder behind your window switches and trunk release on the console?
Old Oct 11, 2009 | 02:53 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Looks nice, but like everyone said, not a big fan of the red screws.
Old Oct 13, 2009 | 03:23 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Good job. Its guys like you that keep reminding me that i still need to have seats redone
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
92GTA
Apr 9, 2016 07:39 AM
g.l.mos
Aug 22, 2015 12:02 AM
Street Lethal
Aug 12, 2015 11:33 AM
