taking apart the louvers
Old Nov 18, 2009 | 03:27 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
Hi, I was wondering, does anybody know the chances of successfully taking these rear window louvers apart? I think they were made by Cragar.
Are they glued? Clicked?
Shipping it assembled will take a monsterous box.
Attached Thumbnails taking apart the louvers-louvers-1.jpg   taking apart the louvers-louvers-2.jpg
Old Nov 18, 2009 | 01:19 PM
Guest
Guest
Posts: n/a
Re: taking apart the louvers
their kinda clicked together....a real pain...if their old 1s id leave them together.
Old Nov 18, 2009 | 02:47 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Those look like the ones i picked up. Mine had a nut and a screw on each side of the middle piece. It looks like a 3 piece setup, but each blade down the middle comes off, or should come off. The nut is real simple to get off even when it's rusty usually, obviously depending on the depth of rust, but otherwise, have fun with the screw, mine were all phillips head screws and half of them would not come out. Had to leave my louvers in Long Island at a friends when coming back upstate because bringing home a LB9 in the back seat of my sunfire was that much more important at the time :-)
Look underneath, should be able to see what i described and if it's put together as i said. Soak it in PB Blaster and pray that it goes easily for you.
Old Nov 18, 2009 | 04:18 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Not really that tough although time consuming. If you were local I could turn that set into something similar to mine for about 450.00.
Remove the two stiffeners by prying off. gently pry up to disengage the locks, 4 per louver. pull each louver from the two end sections. straighten and prep as needed.
Good luck
Old Nov 19, 2009 | 01:56 AM
phoxetis's Avatar
Car: T/A
Engine: 5.0 v8 TPI
OK, thanks a lot for the reactions, let's hope for the best.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Metalizer
Sep 13, 2015 12:56 PM
Fox118
Sep 12, 2015 09:29 PM
formula1LE
Sep 12, 2015 08:31 PM
