So is it really hard to tint thirdgen rear windows?
Old Mar 15, 2010 | 07:38 AM
  #51
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: So is it really hard to tint thirdgen rear windows?
tbh i wouldn't say tinting it is the hard part, thats easy. It's the removal that is a bitch for our cars because we have the copper wiring for the rear defroster. i got quoted for 100$ to only remove the tint on my rear window alone( was already half off and peeling)
And then the same store said 150$ to tint 30% for both doors and rear window all together
Old Mar 18, 2010 | 04:59 PM
  #52
georgeallenher's Avatar
Car: 1991 Camaro RS Coupe
Engine: 5.0 305cc small block
Transmission: 4-speed auto 700R4
Axle/Gears: (axle 8.5 inch 10 bolt) (2.73)
Wow thats really expensice. Yeah recently had my windows tinted for 100.00 even. They said the rear window was extmremely difficult due to the defrosters, they had to cut around it. By the way these were master window tinters and it took them 4 hours to finish. I also had the top of the winsheild tinted, it looks sweet! Goodluck man!
Old Mar 28, 2010 | 11:01 AM
  #53
johnblaze322's Avatar
Car: 92 camaro
Engine: V6
that is way to much money i got just my rear hatch in my 92 done for $60 here in new york... about 30min outside the city and a few years back i got my all my 84's windows done for $150 if your close ill give you the name and number of the place that did mine he did a awesome job
Old Mar 28, 2010 | 12:05 PM
  #54
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
$100 for side windows and rear 5%. The back window didnt come out bad at all except for a small crease in the lower right side. The key to getting the back window done right is to use a heat gun and alot of patience.
Old Mar 31, 2010 | 08:23 PM
  #55
91rsV8maroon's Avatar
Car: 91 rs
Engine: 3.1
Axle/Gears: crippled
easy
Old Mar 31, 2010 | 08:24 PM
  #56
Car: 91 rs
Engine: 3.1
Me and my friend tinted mine, i just laied on my back with the hatch open and he rolled it out and trimmed it then handed it to me and i just squeeged it on and it looks really good. No bubbles or anything, everyone askes me if it's pro and i just smile...
Old Jun 11, 2010 | 09:11 PM
  #57
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Somebody please tell me what to use to remove the adhesive residue from the old tint. I managed to peel the old tint off my hatch but the now non-sticky adhesive was left behind. I tried a bit of gasoline and it worked but I prefer a less toxic and less flammable way of doing it.
TIA!
Old Jun 12, 2010 | 04:09 AM
  #58
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
TIA!
IIRC, ammonia or even a steamer might work. Try Googling or Youtubing the topic there used to be a lot of videos on the subject where they showed how to do it and such.
http://www.youtube.com/results?searc...t+removal&aq=f
Old Jun 12, 2010 | 07:48 AM
  #59
pwdbychevy's Avatar
Autozone sells a window tint removal spray.
Old Jun 13, 2010 | 05:05 AM
  #60
84imsa's Avatar
Car: 1984 Camaro
Engine: 327
Thanks for that!
Autozone sells Gila / 8 oz. Window Tint Adhesive Remover with Scraper for $6.99.
Old Jun 19, 2010 | 10:06 PM
  #61
jesusramirez817's Avatar
Car: 1986 trans am
Axle/Gears: non posi : (
i only paid $60 bucks
Old Jun 20, 2010 | 11:41 AM
  #62
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
You don't need to buy any tint remover of anything like that. Some soapy water and a razor taken from a OLFA knife will work perfect. I had old tint off in 10mins.
For the defroster on the rear , again use the razor and scrape it off. It comes off easy. My car does not get driven in the winter so I had no use for the rear defrost. The bands on the inside of the window just pull off , then scrape and wash the lines away.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
