Trunk Trim
Old Nov 30, 2009 | 09:15 PM
lbarile1991's Avatar
Trunk Trim
Has anyone attempted to paint the trunk trim? The trim is so scratched up and it scratches very easily and just does not look very good at all. Any tips on how to go about painting this to make it look somewhat factory? Either the gray color or even a satin black? The plastic is kind of soft, Should I sand it down? Any help would be amazing
Old Nov 30, 2009 | 11:11 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Trunk Trim
1. Open a beer
2. Sand down the rough spots (if any) with a 400 grit.
3. have aonther beer
4. Spray with Crylon satin black plastic spray.
5. Use even coats and let dry.
6. Have another beer
Should do the trick.
DO NOT OVER SAND.
Old Dec 1, 2009 | 12:40 AM
Re: Trunk Trim
Thank you...The sanding was the part I was not sure of.
Old Dec 1, 2009 | 12:52 AM
Awesome-X's Avatar
Car: 87 Camaro
Re: Trunk Trim
At least there are some enjoyable steps to this how-to
Old Dec 2, 2009 | 01:09 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Trunk Trim
i used the touch up pen/brush you can get at any store, the duplicolor black or gloss black.. took like 20 minutes. not pro, but black again
Old Dec 3, 2009 | 02:55 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Re: Trunk Trim
i did mine by just sanding down the rust spots and then adding a layer of black paint. i might need to put another coat down but it did the trick for the summer.
Old Dec 6, 2009 | 07:21 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
Re: Trunk Trim
now i know why mine didn't turn out, I forgot steps 2,4 and 5, Seriously though, I was curious about painting mine too, now I know what to do, and buy to get r done.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
