brushed alum tpi setup
Old Jan 18, 2010 | 04:33 PM
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
The natural, polished and the painted look are all ok, but I want something different.
The only mod I have for the TPI are SLPs, and would like to have the brushed alum finish to the whole setup.
The first step will be to polish and plenum and runners but from there I have very little info on how to create the brushed look. If I try to do this manually the lines will overlap; hence the turnout will be tacky.
any input?
Old Jan 18, 2010 | 04:41 PM
JMR's Avatar
JMR
Re: brushed alum tpi setup
ok a little google did wonders
i guess scotchbright pads or a steel wool pad will work?
Old Jan 18, 2010 | 04:56 PM
BADNBLK's Avatar
COTM Editor
Scotch brite pads and WD40 for lubricant... there was an article in Popular Hot Rodding where they talked about it. Just too lazy to search for it!
I hear its hard to maintain, and is best when coated with clear powder, or paint.
Old Jan 18, 2010 | 06:53 PM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
my guess would be use the scotchbrite or steel wool then put a satin or semi gloss clear over it so it would be easier to take care of..
I've been debating doing the same thing actually. Im sick of the stock TPI unit under the hood and dont have the money to put a different setup on it.
Old Jan 18, 2010 | 11:11 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Engine enamel paint...comes in LOTS of colors.
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
