Which Duplicolor silver.....
Transmission: World Class T-5
Axle/Gears: BW 3.45
....best matches the silver ground effects on an '82 -'84 Z/28?
Before anyone says "get the color code", I have. I had both a touch up pen and had some spray cans made with the correct code. I know metallics are tough, but it just comes out substantially darker.
I bought a can of Duplicolor Silver Metallic as an experiment, and it's actually closer than the "real" stuff, but maybe a tiny bit too bright.
Any advice?
Any advice?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Which Duplicolor silver.....
Remember that the stuff in the can matched the paint as was in the factory, not how it is now after 25+ years.
Hit up your local auto body supply shop. Have them sample the existing paint. They'll have a gadget that they hold against the paint and it tells them how to mix paint to match. Then you can have them put the mixed to match paint in a spray can. They could probably do a bottle of touch up if that's all you need too.
Axle/Gears: BW 3.45
Oh, for sure. But it's just plain the wrong shade of silver out of the can - too dark and brownish. Actually, I've already repainted 3/4 of the ground effects, so matching it to the old paint is no longer the issue. As soon as I find the right shade of silver, I'll probably repaint whole thing again..
Axle/Gears: BW 3.45
I think I'm beyond the touch up stage, (see above post). Plus, I'm not sure that putting the right (metallic) paint in a can will give the right color when sprayed. As soon as I can find a mass marketed silver in a can which matches the correct color, I'll redo the whole deal.
Axle/Gears: BW 3.45
Could be Duplicolor 301D silver mist DSGM503.
I'll find some and let you guys know.
Axle/Gears: BW 3.45
Okay. I only did a small test area on my front spoiler, but it looks like Duplicolor silver mist DS503 is a match for our silver ground effects.
You'll have to order it from NAPA since you probably won't find it off the shelf.
Can't wait until it's warm out!
crazy3rdgen
Sep 15, 2004 05:17 PM
CamaroZ_85
Apr 21, 2001 03:19 PM
