Sylvania Silverstar Parking Bulbs
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Just bought the clear parking/side marker lights off ebay and they look great. I went and bought some sylvania silverstar 2057A ST turn signal bulbs, and they won't flash when I turn the turn signals on with these bulbs in. I searched to see if anyone else had this problem but found nothing, what am I doing wrong?
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Sylvania Silverstar Parking Bulbs
Look at the contact points on your new bulbs and old bulbs, compare them. There are several dual filament bulbs that have subtle differences. This could be your issue
Engine: LSx 5.3
Yeah my flashers are good, the old bulbs will flash when they are in. On another note, I seem to remember the bulbs going in the sockets but I couldn't get them to twist and lock
Car: 1986 IROC T-TOP
Transmission: 700-R4
Bulbs shouldn't make a difference. The flashing is because of the flasher circuit turning off and on. If they do illuminate, the bulbs are good. Unless the flasher is after the bulb and removed the ground in order to make them flash. IF that is the case and there is a short keeping it grounded they wouldn't flash. I'm not familiar with the circuit though.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The 2057 bulbs have two contacts on the bottom, one for each filament, ground is supplied by the metal body of the bulb. They do need to twist and lock in place in order for the contacts to line up correctly in the socket.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Engine: LSx 5.3
Alright thanks guys I appreciate the help, i'll give that a try today
Engine: LSx 5.3
Well today I felt like a complete idiot
I pulled the bulb out of the socket and found out that the little round locks on the bulbs are offset and all I had to do was pull the bulb out and twist it 180*, put it back in the socket and it locks in place now. Thanks for the help guys.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the simple solution/easy one is often the best . the only dumb/stupid question is the one that is not asked . don't feel bad we have all done the same thing . good luck .
RedLeader289
May 28, 2019 01:47 PM
