5thgen taillight mod
Old May 30, 2010 | 12:51 AM
  #51
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: 5thgen taillight mod
Originally Posted by 1bad91Z
That pic looks halfway decent! More 2ndgen looking than 1stgen though..
they're cut down third gen lights, I'm not doing the first gen mod, I was just say'n they would fit the car better than the "new camaro" tailights, mine are kind of a mix of 2nd, 3rd, and 4th gen
Old May 30, 2010 | 02:56 AM
  #52
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
http://www.fbodymotorsports.com/inc/sdetail/12339
Has anyone heard of this / done this?
I think this could be made to look slick!
Old May 30, 2010 | 03:06 AM
  #53
ericjon262's Avatar
someone on here has done it, I saw pics a while ago, it looked alright, but too many people already think a Camaro is a poor man's corvette.
Old May 30, 2010 | 08:25 AM
  #54
Stephen's Avatar
Car: 87 GTA
......I'm trying to come up with something different from the common (run-of-the-mill) stock lights..
Take some some stock lights....
Doesn't matter what the lenses look like or if the lenses are even busted(in fact, even better since you could get those cheaper!)......
Pull the lenses off.....
Buy some lexan sheets....
Heat them up to form the wrap around ends that Camaros have.....
Paint them to your hearts desire on the inside, creating whatever pattern you want, like FYRCHKN did his, to some stock lenses.
Old May 30, 2010 | 10:32 AM
  #55
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Originally Posted by ericjon262
I think 1st GEN taillights would fit the car WAY better, they would match the lines better, or you could do like I'm working on,
https://www.thirdgen.org/forums/elec...aillights.html
Keep in mind I will do the name "Camaro" body color, not stark white, also, if thats your car, thanks for letting me chop it up!
Looks good, but not as good as the stock thirdgen stuff.... Can't mess with success.
Old May 30, 2010 | 11:08 AM
  #56
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I like what FYRCHKN did, but I think I would end up trashing the lexan while heating/bending it. I'm more skilled with metal.
Old May 30, 2010 | 11:24 AM
  #57
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
I'm torn on what i think about it.
On one hand it'd be nice to see an interesting new mod. But on the other hand you have a beautiful third gen and i'd hate to see anything compromise that. But in the end its your decision, if you have the $ go for it as long as it bolts on.
One question, so your going to be modding an existing third gen light housing to make it fit? If so wouldn't it be a total PITA because you'd have to weather proof it and somehow bolt the new lights in where the old lens used to be? i'm a little confused on this part.
But if anyone could make this mod look good it'd be you and that beautiful camaro, so good luck!
Old May 30, 2010 | 12:26 PM
  #58
Stangski09's Avatar
I say go for it! It'll be a great mod when completed, and if it doesnt fit your expectations you can always go back to stock.
Old May 30, 2010 | 01:50 PM
  #59
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks for the kind words!
As far as the weatherproofing, the housing would be completely made out of metal (probably aluminum) and would be fully tig welded, ground smooth, and sealed on the inside with seam sealer. The housings will be the same shape as the stock lights to make them a direct swap. The only thing I may use are the black plastic pieces (the area circled in yellow in the previous pic) that contain the license plate lights. Then those pieces will be modded for reverse lights. So far, that's the theory...
Old Jun 1, 2010 | 05:18 AM
  #60
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Please, don't do it. those tailights look nasty on a new "Camaro", but on a thirdgen, just don't go there.
I agree, i dont like them on the new camaro so they wont work on a thirdgen either
I also agree. One of the things I can't stand about the 5th gen is the taillights. And they look even worse on the 3rd gen! I can't stand the shape of them or why the heck they have "chrome" trim around them.
If anything, the 5th gen might look better with the 3rd gen taillights.
Old Jun 1, 2010 | 07:26 AM
  #61
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Well, I just priced out a new set of 5thgen lights and even with my discount, they are still pretty expensive!
So, if anyone has a line on a used set in decent shape (maybe from wrecked car hit in the front), then please let me know!
Old Jun 1, 2010 | 09:29 AM
  #62
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I've seen it done. It doesn't look very good in my opinion but at least its reversible.
Old Jun 1, 2010 | 08:01 PM
  #63
NT-Z's Avatar
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
Originally Posted by Mr. IROC-Z
I usually don't chime in too much on stuff like this, but goddamn, this picture looks RETARDED! Spend the money on your engine, or something else. Modding the tail lights 5thgen is a waste of time and money.
All those pics look retarded and a waste of time, even the Rad Rides by Troy.
Old Jun 1, 2010 | 11:12 PM
  #64
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Well, I see all these hate posts, but I rarely see a constructive reply about different ideas other than "leave it stock"...
If there are other taillights from other vehicles that you think would mold or blend well with a thirdgen Camaro, then please let me know.... other than "Stock"....
Old Jun 2, 2010 | 08:32 AM
  #65
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
same here. I tried taking the grid out of an old delaminating spare set of lights I had, and I put a hole in the outer lense.
Old Jun 2, 2010 | 08:45 AM
  #66
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i say go for it man i think it will be bad *** once its done, you caught heat on here for your wheels but everyone who sees them in person loves them
if you wanted an alternate taillight to use, a first gen camaro light might work, but it also might look too old for a third gen...
Old Jun 2, 2010 | 02:10 PM
  #67
ericjon262's Avatar
I think that would look way better than the "5th gen" "camaro" tailights.
Old Jun 2, 2010 | 02:13 PM
  #68
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
hmmmm
Old Jun 2, 2010 | 06:07 PM
  #69
tekkitan's Avatar
Car: 87 IROC-Z
Originally Posted by darkhorse91
first off, megan fox has big toes for thumbs and it just creeps me out.
Some people are way too picky :P
Old Jun 2, 2010 | 07:03 PM
  #70
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Camaro lights are styled into the whole rear bumper, into the spoiler, and into the rear quarter panel. It's becuase they wrap around and they are a central part of the styling theme of the car to fill the space between the bumper and the spoiler that you're gonna hav ea hard time doing anything unique with them. Having a blank piece of plastic/fiberglass whatever wrap around on the side looks pretty crap, honestly. Messing with the shape isnt really something that's gonna be easy to pull off. The colors, yes, but not really the shape.
Old Jun 3, 2010 | 08:37 AM
  #71
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I'm going to start off with the shape of a stock taillight and modify the metal housing from there to accommodate the lines / angles of the new lights. When I'm done, it will be a direct bolt-in, but may have a slightly different shape when they are done.
I'm still looking for a decent set of used lights because new ones are too expensive.
If anyone has a line on a good set of used 2010 camaro taillights, please let me know!
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
pimprs
Sep 10, 2015 03:34 PM
