Removing anodizing
Old Sep 19, 2001 | 04:33 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Removing anodizing
I just sent a set of wheels to a shop to be polished out and was notified that the rims were anodized. I used aircraft paint stripper on them and except for the center section paint coming off(GTA style wheels)everything else stayed the same. Is there a chemical out there that will remove anodizing? Could it possibly be sanded off without damaging the wheels? Someone help!
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Old Sep 19, 2001 | 05:59 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
http://www.caswellplating.com/frames...=/aluminum.htm
check there. if you see at the bottom they have a solution to remove it for 38.00
Not sure how it works. You'd think a company that does things to wheels would know how to remove that stuff.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: B&B Exhaust, few free mods.
Appearance Mods: SS wheels, 2.5" Cowl Hood... New 100% Black paint job, Clear Side Marker Lights
Stereo: Alpine 855, Infinity Kappas all around, Infinity 150x2 amp (POS), Infinity Perfect 10 in hatch.
Pictures are Here
ICQ: 1437212
AOL: normalmatt9
Old Sep 20, 2001 | 08:15 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
If you check around, a lot of guys have polished their own rims, but I've never heard any mention of them being anodized. Maybe these guys don't know what they are talking about. Even if they are anodized, I don't see why they don't just polish it off.
Anodizing is just a coating and will wear off.
Old Sep 21, 2001 | 07:04 AM
Mongoose's Avatar
Car: 90 Formula
I don't understand the whole concept behind anodizing but I have talked with several metal finishing companies and they all say that it must be removed before polishing and chemically seems to be the only method worth the effort. I checked with Caswell from the links above and I'll be using their products for this.
Old Sep 21, 2001 | 01:13 PM
Saywhut's Avatar
Jestco Products, 1 888 581 1655 / 864 845 6311 has an anodize remover in their catalog, 16 oz, $8.00, gal, $32.00.
It's a powder you mix with warm water.
I haven't used it, just passing the info, but I have used & been well satisfied with their other products.
Old Dec 29, 2004 | 02:08 AM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
I just did a search on anodizing and ended up finding this really old post..so I figured I would give some info. Anodizing can be removed with "Easy-Off" brand oven cleaner. It is a very strong acid (sodium hydroxide I think) and eats away the oxidation on the surface of the aluminum. Anodizing is actually a process that "dyes" the oxidation on the surface of the aluminum. It is a PITA to sand off because the anodizing is actually harder than the aluminum itself. So like I said, to get it off you can buy a can of Easy-Off for $2, spray it on, let it sit for about half hour and then rinse it off and hit it with some steel wool, it may take a couple of repeats to remove it all but it will be ok. Just a word of warning, when you let the oven cleaner sit on the aluminum it will turn it an ugly grey color, but that sands/polishes right out. Hope this helped a little.
Old Jan 1, 2005 | 06:27 PM
92_maro's Avatar
Car: 92 camaro, custom wheels, paint exhaust, chipped
Engine: just the rs
Transmission: auto
yeah just use over cleaner, dosent even have to be a certain brand
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
