DDM HID's..help?
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
DDM HID's..help?
so i got the 55watt 10k slim ballast kit from DDM..and the ebay projectors..
now...i understand the basics of wiring and what have you but WTF..i cannot figure this thing out....soo yeah please help..heres what im trying to go off of...
http://docs.google.com/viewer?a=v&q=...LgeodK_2wqsa4w
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: DDM HID's..help?
the harness looks pretty straight forward, provided the ends are correct for your cars existing lights.
what exactly are you having issues with?
Engine: 5.7 350 TPI
how do i connect it to the power? O.o i dont see how it works... and i dont see how it goes into the stock headlight wiring..
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That harness is designed for a car that uses the 9005/9006 lamps
Like this...
Like this...
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
C - batt
B - ballast(make sure the clip faces OUT)
A - headlamps.You dont need the 9005 connector, but it helps.If your wondering what they look like.Refer to B connectors.
Get a multimeter & find which two wires turn your lo beams on.Thats what A will connect to.
How you choose to attach A to your lo-beams is up to you.You can
A. cut both ends & crimp them together.
B. get the 9005 pigtail
C. cut only the DDM plugs & crimp on flat spade terminals.Then connect them to your OEM plugs.
Engine: 5.7 350 TPI
oh i already got it
thanks guys!! ill post a thread about how i did it later today.
thanks guys!!
thanks guys!! ill post a thread about how i did it later today.thanks guys!!
CrazyHawaiian
Oct 1, 2003 09:41 PM
