GTA Rims Help
Car: 1984 Trans Am
Axle/Gears: 3:73
GTA Rims Help
Hey guys i recently purchased a set of gold cross laced GTA rims. I got a good deal on em but they need some TLC. So i decided to sand the lips down eventually. Now im in the processes of planning everything out. I plan on doing what this guy did http://www.gmtips.com/3rd-degree/dox...els/wheels.htm . But idk if i should repaint the centers. Im 15 and am on a budget. I can afford to paint them with some quality spray paint and that is about it. Will it come out okay or is it B**CH to get the paint evenly on the rim. I know to use some etching primer, but what paint should i get that is good quality and matches the original gold color. Something that is durable. And should i paint em???
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: GTA Rims Help
wait at least 24hrs before bumping a thread, patience
just pick up some wheel paint, its not that expensive. If you tape everything off, it will look great when you are done. Just make sure the centers are clean and degreased before you paint or it will fish-eye.
I just did a set of gta wheels over the winter, they came out pretty nice. The bare aluminum lip needs to be sealed, not painted. Most clear coat will not stick to bare metal, you would have to fine clear paint. good luck
i used Zoopseal on the lips, working well so far, but its not cheap.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: GTA Rims Help
Mine started out gold, but I used Rustoleum rattle can gloss black on mine about 2 years ago. They still look great.
Car: 1984 Trans Am
Axle/Gears: 3:73
Car: 1989 pontiac firebird trans am GTA
Engine: TPI 350
Transmission: auto 700r4
Axle/Gears: borg warner 9 bolt and 3.27
Re: GTA Rims Help
just a quick question here but what is the best way to get built up brake dust off gold laced gta rims, im afraid if i scrub the rims the gold paint will come off
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: GTA Rims Help
Sand the lips with say 400-600 to start work your way up to 2000 grit, now sand the crosslace sections with 400-600, maybe work up to like 800. clean the wheels good, once nice and dry tape off the lips and paint the crosslace sections with a good spay paint. then polish the sanded lips and they should look killer.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: GTA Rims Help
I picked up a set of red ones about a year ago
and redid them in White
I did all the things that fellow did in the site you have listed except polishing(I'll do that now since my car is back from the paint shop).I think I only used 3 cans of Dupli-Color Perfect Match WA8554 White(same color as car),you need to apply multiple fine coats,you Don't want to load it up and have runs and drips.Take your time between coats and let it dry according to the directions(BE PATIENT,DON'T RUSH)and everything will turn out with outstanding results
Engine: 5.0 EFI
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: GTA Rims Help
Look good in white man as ive never seen them painted that colour
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
Re: GTA Rims Help
Rustoleum wheel paint. It's cheap and if you take the time to do good prep work they'll come out great. I spent a weekend sanding down my camaro rims. Then a coat of primer, couple coats of black wheel paint followed up by a couple coats of clear. Just remember the better job you do prepping the wheels the better your paint will look.
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
