Sratches....easily touched up? Or must the entire panel be repainted?
Old Sep 26, 2001 | 01:00 AM
Yellow Camaro's Avatar
Can paint scratches be touched up? Or do you need to get the whole panel repainted? The scratch basically looks like what it would look like if somebody relatively lightly scraped it with a key, but the scratch is in a funny place such that I don't think that's what happened. Is this a cheap fix?
Old Sep 26, 2001 | 03:14 AM
Roshambo's Avatar
Well, if I were you, I would go to Wal-Mart (the one here has a LARGE selection of GM code touch up paint) and try that.. if your car isnt GM code, they may have it there.. make sure the scratch is clean.. and take your time, if its really minor, no one should even notice it when your done. Good luck!
-Roshambo
-Joe
1988 Pontiac Trans Am WS6 - 305 TPI, 700R4, 3.23 Posi, Digital Dash, Leather Seats, Maui Blue with Silver GFX, T-tops, Tinted Glass, Gutted MAF, TB Coolant Bypass, K&N Cone Filter, No Cat, 3" exhaust from Y-pipe back, MSD Super Coil, Accel 8mm wires, L98 Aluminum Heads, Ported and Polished Plenum, Siamesed Intake, Aluminum Driveshaft, Edelbrock 3 point Strut Tower Brace
Old Sep 26, 2001 | 08:30 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I touched my fairly large scratch up pretty well using the tech article on here. Fill in the scratch with touch up paint, wet sand with 2000 grit paper. Repeat. then apply clear coat, wet sand with 2000 grit paper. Then use 3M fine cut rubbing compound and then 3M swirl mark remover. Mine looks ALMOST perfect. Good luck.
1992 Camaro RS
5.0L TBI
Custom white-faced gauges
K&N Airfilter and ready to take on the world!
My 1992 RS
Down with bin Laden
Old Sep 27, 2001 | 12:53 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
If the scratch is very light then any polishing compound should take it off. If the paint is gone and you can see primer or metal underneath then to do it right the whole panel would have to be redone. I used to work at a body shop and we did a lot of restorations and if the car was ever scratched we would have to repaint that entire section. Even on cars that were keyed in the parking lot customers were shocked to find out that every panel that was keyed would have to be repainted or blended onto.
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
327IROC85
Sep 23, 2015 12:11 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
