projector hid headlight help. ebay item of course.
Old Oct 14, 2010 | 11:29 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
ok i have bought these lights and had them professionaly installed and they just dont seem to be bright at all. at least on the ground. my foglights are more help. and one keeps going out but i can turn them off and right back on and it kicks on. anyone have these lights installed and have problems. the ebay store is racer innovation one of the tops. please help.http://cgi.ebay.com/ebaymotors/12000...essories#rpdId
Old Oct 15, 2010 | 02:32 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
Re: projector hid headlight help. ebay item of course.
I have heard that the h4 bulbs have the same connector, but different pin associations. You need to re-pin two pins. If that has been done, there is a Phillips screw on top in the center to adjust the headlight down or up. Hope this helps
Attached Thumbnails projector hid headlight help. ebay item of course.-connect.gif
Old Oct 15, 2010 | 02:43 PM
Ninety-One's Avatar
I'm sorry I wasn't paying attention i thought they were just the hid housings with h4 bulbs. So try adjusting that screw to see if you can aim them up more/down more. Sometimes its good to park towards a wall and adjust them like that.
Old Oct 15, 2010 | 03:44 PM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
ya there for the most part pointed down. could it be a bad ground? or because its not grounded to the battery? i am not good with electricity. lol
Old Oct 15, 2010 | 03:56 PM
Downshift's Avatar
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Do your bulbs have two bulbs stuck together in each bulb? Does it look like it has a small H3 type bulb with a white base next to the long thin glass bulb?
Old Oct 15, 2010 | 03:58 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
it is because they are cheap crap, 90% of the ebay housings and bulbs are junk...your better off with a set of silverstar replacment headlights
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
no there is only one bulb.
Old Oct 15, 2010 | 03:59 PM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
thats what i was expecting. just bought for looks but expect them to be driveable at night
Old Oct 15, 2010 | 04:01 PM
Pillsbry10's Avatar
mine were HOOOOORRRIBLE, i could never see at night with them...went back to stock so i could actually drive at night
Old Oct 15, 2010 | 04:05 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
Oh, some kits come with H.I.D low beam and Xenon Charged High Beam. They have two bulbs in one and sometime people wire up the wrong bulb (xenon charged) so it doesn't look bright enough. If the H.I.d is lighting up and you just don't seem to get good light projection it might be because of the black housing on the conversion headlamps. Black housings do not reflect the light foward very well.
Old Oct 15, 2010 | 04:07 PM
Pillsbry10's Avatar
the housings seem to always be the problem, mine were super bright but the light was just going out all over the place instead of being focused towards the road
Old Oct 15, 2010 | 04:24 PM
Downshift's Avatar
Car: 91 Camaro Z28
Transmission: 5 spd
I am running an 8K system in the headlamps and a 3K system in the fog lamps. The conversions I used are chrome but they have the O.E style refector lens. They work really great. They system I use is O-NEX. I have had them on my truck for 3 years (no problems) and just recently put them on my camaro. Here are some pics. Maybe you should get different conversion housings. Good Luck Bro.
I used the conversion heal lamps in the bottom half of the pic.
Old Oct 15, 2010 | 06:16 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Those housings are pure junk. That is not a projector. Not to mention that those are 12k HID's. That's going to put out less light than even our stock halogens. If you're expecting to see very well then you need something closer to 5300k.
Old Oct 15, 2010 | 08:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
First off you have black housings!Black absorbs more light than any other color.Reflector lamps should be chrome, since chrome would reflect the most light.
That said even if you had bought chrome units.It would'nt be much better.Even with HID lights.Those lamps are not designed for illuminating the road.They're mostly for show.Also the more color you have , the less useable light there is.Thats three strikes so far.
Also if you are NOT using a HID harness/relay & just powering the ballast right off the existing wiring.You will not get enough current to your ballast.This will cause the HID lights to flicker/shut off &/or flash.I didnt bother reading the auction description if the kit comes with a harness, but it you are'nt using one, you should be.
Repeated flashing/flickering or any situation that causes your HIDs to act the way yours are.Will eventually damage the ballast & probably the HID lamp too.This is why you should alway use a harness W/RELAY & power the ballast off the batt.I dont care how many people say they are not using a harness/relay w/their HIDs.
There are a few posting regarding these ebay projectors lamps too & how shitty they perform.Pitty people keep buying them.They are not actual projectors....end rant.
Old Oct 16, 2010 | 03:51 AM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
I am using a harness and relay. Kit did come with one. They are junk housing and bulbs. Is here anyone that produces a housing (hid) lamp that I can plug in with the rest of this kit? Thanks forth help an advice and one of my bulbs.will turn off then I can turn it right back on.
Old Oct 16, 2010 | 12:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not really any to speak of & more important.Reflector housing are not designed/intended for HID lights.You would not be taking full advantage the HIDs this way.Plus you'll have hot spots(glare).Maybe the housings pictured in the red camaro above.They seem DOT spec, but even then.......
......As good as some will tell you how much better their lights are with HIDs (over OEM) & a reflector style housing.It would be better still with a dedicated HID projector.There is a H4 projector (hella, i think) produced, but even then, its not a purpose built HID projector.H4 is a incandescent bulb, H4 HIDs are merely adapted to fit a housing that originally came w/an H4 bulb.
Any HID lamp that is NOT either D1S or D2S.Is just an aftermarket HID lamp modified to fit incandescent style housings.OEM systems use D1S, some use D2S & these systems all use projectors not reflector housings.
As for color, typically OEMs use 4300k lamps.Reason being is they offer the most useable(white) light.All other kelvin rated lamps are just aftermarket.Its easier to see things/read signs with a white light, than with a blue/purple/ light.
Id check your harness/connectors or even the HID lamp itself for the on/off issue.Have you tried swapping the lamps over to see if the problem stays on the same side or moves over with the lamp?
Old Oct 17, 2010 | 12:04 AM
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Any thoughts on these. #4656 - 6-1/2x4 Rectangular
HID Low and Halogen High Beam Kit
http://www.brightheadlights.com/hid-upcoming.htm
Old Oct 17, 2010 | 12:29 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I've seen another car with the ones in the link just above, and he said they were good and DOT approved. I find it hard to pay $1000+ for some headlights though. I don't like the way they look because the front of the glass on the projectors sticks out much farther than the original style of light. The name you might look for is sinister or sinisterz. Pretty sure he's on here if not on fbody.com
Old Oct 17, 2010 | 01:24 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Originally Posted by josh006
Any thoughts on these. #4656 - 6-1/2x4 Rectangular HID Low and Halogen High Beam Kit
Ive seen those as well on the forum.Id like them better if i knew what kind of projector that is, but never for that price.Too much money.You could retrofit projectors for less than half that price.
Im with fast82.I dont like how that lense is bulging out.Thats done cause the projector is mounted way forward, but it looks funny.
Drone358
Dec 10, 2015 08:16 PM
R13_Braz
Sep 18, 2015 05:00 PM
timonator
Sep 13, 2015 11:49 AM
e3pres
Sep 9, 2015 01:51 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
