What is this thing and can it be removed?
Old Oct 21, 2010 | 01:58 PM
stackofire's Avatar
Car: 1991 Camaro Z/28 305
Hi everyone.
Don't know if that's the right place for that question but here it goes.
What is the part circled on the pic? What is its role? Where those two hoses connect to? and Where small line connects to? Can it be removed altogether? Advantages/Disadvantages of removing it?
I'm cleaning engine bay and it looks awful.
For the records I removed A/C and A.I.R. system long ago (don't need it in Europe).
I would do a search for it but don't know what it's called.
BTW the car is 1991 Z28 305
Thanks in advance for answers.
DSCF0478-1.jpg?t=1287687481
Old Oct 21, 2010 | 02:02 PM
Twin_Turbo's Avatar
Re: What is this thing and can it be removed?
heater valve, it stops hot coolant from flowing through the heater core w/ the heater set to off or AC on. It makes the AC more efficient. My 88 non AC doesn't have one, yes it can be removed. You can also keep it and relocate it.
Here's a pic of my white 88 w/ no heater valve and my red 87 converted to ac delete and the valve relocated:
the non ac one, it has that 90 deg tube where the other has the valve. The other line runs directly to the KC4 oil cooler, if you don't have it, it goes to the rad
it's between the inner fender and the ac delete box
the small line is a vac line, controlled by your heater controls.
Old Oct 21, 2010 | 02:05 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
it is the heater control valve. vacuum controlled (little rubber hose on top). bottom coolant hose goes to the heater core. top hose goes to the coolant pipe on the passenger side fraim rail. right coolant hose goes to the intake manifold base.
can it be removed, yes. but theres no point unless its broken, or you dont want heat. you could just reroute the hoses and plumb it out of the system. that whole system covers the heat and engine oil cooler. and it looks like you doint have the oil cooler. so yes you could tidy it up a bit and reroute the hoses....
Old Oct 21, 2010 | 02:10 PM
Twin_Turbo's Avatar
with it removed you still have heat. It does not interfere with the functionality of the heater. It's only used to shut down hot coolant flow when the heater is off or the AC on so you are not trying to cool down a hot heater core. NON AC cars don't even have one. The heater core always sees hot coolant flow with the valve removed.
Old Oct 21, 2010 | 02:50 PM
stackofire's Avatar
Thanks for the info guys. So I would remove it, do I need to plug some holes? What to do with vac line?
Old Oct 21, 2010 | 02:56 PM
Twin_Turbo's Avatar
plug the vac line otherwise w/ the heater controls set to off or AC you will have a vac leak. If it were me, I'd keep it and reposition it. In the summer w/ the heater set to cold it won't heat up the interior as bad from the hot heater core.
Old Oct 21, 2010 | 03:20 PM
stackofire's Avatar
Thanks. I will probably go with that...
Old Oct 21, 2010 | 09:11 PM
Abubaca's Avatar
For awhile, I had mine rerouted to run right along the frame rail. ...I eventually removed it all together.
Old Oct 24, 2010 | 05:20 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I also removed mine,,,no big deal
Attached Thumbnails What is this thing and can it be removed?-ls1-brake2.jpg
Old Oct 24, 2010 | 07:33 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
So shiny. How did you get it so shiny? Or are those all chrome pieces apposed to the aluminum ones from the factory?
Old Oct 28, 2010 | 12:36 PM
stackofire's Avatar
One more questions guys...
If I will decide to remove it I know I need to plug the hoses that go to the heater box and the vacuum line, but what to do with the hose that goes into throttle body? Should I plug the TB or just leave it open?
Old Nov 12, 2010 | 09:37 AM
shone190's Avatar
I'm also interested for answer about "what to do with hose from throttle body"
Old Nov 12, 2010 | 09:39 AM
Twin_Turbo's Avatar
if you remove it you won't have to remove the hoses to the heater core. If you do that you won't have a heater. If you remove the hot water vale there's always hot coolant circulating through the core, that's all. might not be a bad thing to have a working heater in Schotland.
The throttle body hose, well it depends if you want to retain the coolant flow through the TB or not.
Old Nov 12, 2010 | 10:05 AM
stackofire's Avatar
Thanks for that. I will probably run the hose straight from the heater to the engine block... Can that be done?
Can you guys tell me which way the coolant flows? Is it from the radiator to the heater core, from there to heater valve, from there to throttle body and from TB to the engine? Is that right? How it goes back to the radiator? Through lower radiator hose?
So if that's the right way of coolant flow can I remove heater valve and by-pass TB and go straight from the heater core back to the engine?
Can you confirm the flow of coolant for me using this pic? I marked it (very badly) how I think it flows which is probably wrong
20032010079-1.jpg?t=1289577897
Thanks in advance.
Fronzizzle
Mar 18, 2019 08:29 PM
Bob88GTA
Aug 18, 2015 03:31 PM
kyleb24
Aug 15, 2015 08:24 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
